Results 1 to 9 of 9
Thread: increasing water pressure
    DIY Junior Member Mr Russ's Avatar
    Jul 2012
    LA.
    Default increasing water pressure
    I was wondering if I can do anything about increasing my water pressure. I have city water and I experience pretty low pressure in the evening(5-9). Mornings arent bad. So im guessing its from everyone using the water at that time. I have all PVC/CPVC piping thru my house which is on piers. I was wondering if anyone had experience with this that could give me some advice. Thanks a bunch.
    booster pump
    Jul 2012
    LA.
    OK. Do I need to get one that only turns on when i open a valve? Is there a certain pressure not to go over with PVC/CPVC piping?
    The booster pumps designed for this act like a well pump. They have a small pressure tank that the pump fills with water - that water compresses a bladder, and when the pressure reaches the desired set point, the pump turns off automatically. So, if you're only using a little water, the pump doesn't have to run. For extended runs, you'd exhaust the small storage tank, and then the pump would run continuously to provide the set pressure. This Olde House installed one, and you might be able to watch that episode from their archives to give you an idea of what it looks like and how it operates.
    AY MCDonald has a "real time" booster, which does turn on when flow starts. They cost qute a bit more than a small package pump system, but are more compact, however.
    Jul 2012
    LA.
    I watched the vid Jim. Thanks
    Is this the one HJ? http://www.aquascience.net/booster-p...ex.cfm?id=1393
    Jul 2012
    LA.
    Hey HJ, I just realized the link i posted is only the installation piping. lol
    So is this a good one?http://www.aquascience.net/booster-p...ex.cfm?id=1385
    Retailer good?
    There's good and bad with having a pump that turns on each time you need hot water. The small tank and pump with a pressure switch resembles a well pump system. It's advantage is it's simple, but the tank will eventually need replacement plus, the pump won't turn on each time you want to wash your hands.
    The inline pump's flow switch may get cranky and not turn on at low flow (which might be a good thing sometimes), but they are less robust than a pressure switch. ANd, assuming you do not exceed the minimum flow requirements, you might find a very fine line between when the pump is off and when it turns on which could lead to some weird results as the pressure suddenly spikes when the pump turns on. Hopefully, it has a soft start which should limit the effect.
    Not having ever lived with either, I can't recommend one over the other and my thoughts are theoretical, based on how they generically work, not specific experience. But, if I were to do this myself, and the slightly larger footprint wasn't an issue, I think I'd go with the tank and pump verses the pump only.
    Dec 2009
    northfork, california
    You may as well get the $59 harbor freight system [might be made in the same place as the link above] and put it on a timer for your morning wash only. Might last a while.
  1. Increasing well water pressure
    By thebone in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-09-2012, 07:53 AM
  2. Increasing Water Pressure
    By midimid in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-15-2009, 12:29 PM
  3. Increasing pressure?
    By steve2278 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-10-2009, 04:56 PM
  4. Increasing Water Pressure
    By Cass in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-19-2009, 09:02 AM
  5. Increasing System Pressure
    By Budster in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-14-2007, 10:41 PM
