sounds like you have a blockage somewhere, could be plugged with iron some where around the pressure switch, are you saying that youre iron filtration is plumbed in before the pressure tank in the house? meaning that the plumbing comes from the pump to the iron filtration then to the pressure switch and pressure tank? This should not be done this way. I would take apart the tank tee and check it for blockages and also the elbow coming from the bottom of the tank.
