Results 1 to 8 of 8
Thread: gas line connecting to water heater
    DIY Junior Member young707's Avatar
    Jul 2012
    San Jose, California
    Default gas line connecting to water heater
    Photo show gas line connecting to water heater.
    What material is this connecting gas line?
    What is this green stuff at the joint into the base of water heater.
    (Yes, I will request gas company to come out and check before turn on this gas line).
    On the threads, it's pipe dope - used to make the joint leakproof. I think the flexible pipe is stainless steel. If you're worried, you can make, or buy some leak detection liquid. Basically some soapy water - look for bubbles. You should be fine. Now, not sure about the rust stains on the tank's outer casing, that indicates a water leak and could be more problematic. Can't tell where it starts.
    The gas line looks fine.
    Like Jim mentions, you can take a spray bottle and some soap. If there is any gas leaking, it will make bubbles.
    Jul 2012
    I measure the distance between the flat surfaces of the brass nut is 1 inch.
    Can you please tell me the size of the stainless steel flexible pipe?
    Does Home Depot or Lowes has longer replacement pipes? Also, do they sell end caps for this type & size of pipes?
    Thank you.
    quote; Does Home Depot or Lowes has longer replacement pipes? Also, do they sell end caps for this type & size of pipes?
    Why would you need them, unless you plan on modifying the gas line? It is fine just the way it is, and the utility company will check and light the pilot when they turn the gas on.
    Jul 2012
    I did not know I should flash the water heater tank? How often?
    Quote Originally Posted by young707 View Post
    Did you mean 'flush'? The act of heating hard water will cause some of those minerals to precipitate out. It doesn't hurt to open the drain valve and try to flush some out say once a year or so. It may not help, and the existing drain valve on most tanks as delivered are really cheap. For better results, you could replace that valve with a ball valve. That gives you a straight shot, less restriction (flushes better), and being a straight opening, would allow you to maybe use a rod to break things up. You could damage your tank if you weren't careful. Many people go the life of the tank and never do this, but in really bad conditions, the minerals can really build up, decreasing the volume and performance.
    Yakima WA
    The flex lines are sold in various length, but as HJ points out, what you have is fine. There is no need for a longer line. Any time you drain a water heater, the heat source must be shut off. A 3/4" ball valve is a good investment. Take the plastic OEM and toss it. Be sure the tank is full before restoring heat. They do make a gas leak testing product, but regular dish soap works just fine. You can dilute it, but I use it straight out of the bottle. Pour it over the joint and watch for bubbles. No bubbles = no leak. Mainly, avoid cross threading and tighten the joints firmly and you should not have a leak. but test them anyway.
  1. Connecting Hot Water Heater Drain Pan to Sewer - Will Swing Check stop sewer gas?
    By Jim109 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-21-2011, 12:43 PM
  2. connecting new yard line
    By dedratermi in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-19-2009, 07:56 AM
  3. Connecting the dimmer switch to the nuetral line?
    By Erico in forum Electrical Forum discussion & Blog
    Last Post: 04-15-2009, 07:27 AM
  4. Connecting instant water heater to faucet
    By mfs54729 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-20-2008, 10:59 AM
  5. Ice maker line from cold line of water heater?
    By ccash in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-12-2004, 06:20 AM
