Originally Posted by
lifespeed
You've received some good advice here, but I'll chip in my two cents also, as a homeowner and user of the freely dispensed advice on this forum.
I have a Fleck 7000SXT 1.5 cu ft softener at 6 lbs/ft for 30K grain capacity to deal with 7 GPG hardness, preceeded by a 1.5 cu ft Fleck 7000 Centaur carbon filter to remove the chloramine from my municipal water 1" copper supply. Like yourself, I was concerned about not decreasing pipe diameter and maintaining a reasonable SFR for softening, as well as not inducing a pressure drop across the softener.
I did accomplish a low pressure drop across the filter and softener, but I do NOT have 1.5" service like yourself.
My family does not typically use 60 X 4 gallons per day, we are pretty conservative like many. at 240 GPD divided into 3857 gals capacity (10% reserve has been deducted) we should go 16 days between regenerations. It turns out to be much closer to 21 days between regeneration, the day override setting I have programmed into the valve. We usually use the alotted capacity before the timer forces a regen, so still very salt efficient.
Some say the regeneration is not frequent enough. However, I think this is only a concern if your water is dirty or has iron/manganese. My water does not, and I have not experienced any ill effects going 3 weeks between regens. I have to agree with Dittohead and others on this point. In fact, if you are to consider SFR as an important system specification, it would be impossible under most water conditions to size a system for 7 day regens unless you have very hard water, while still maintaining a 12+ GPM service flow rate.
As to your your 1.5" water service, I would be tempted if I were in your position to specify a valve with 1.5" internal ports. I may be biased having lived in a house that had inadequate plumbing before I repiped it to 1", but I really don't like high water velocities and undersized pipes. They are noisy, can cause water hammer, and fixtures interact with each other as they fight for restricted flow volumes. I would suggest it might be worthwhile to get the large 1.5" port 2850 valve and distributor tube to operate with minimal pressure drop in your plumbing, combined with the smaller tank suitable for 2.5 cu ft of resin. You may well end up going 2 - 3 weeks between regeneration, but this will be fine, and also salt and water efficient. Consider a carbon filter to remove chlorine. It is an added expense, but it is really nice not to have chlorine in the shower and your drinking water, and will prolong softener resin life. SST-60 resin is nice and the added expense is small, although not strictly necessary.
Finally, I prefer a reverse osmosis system under the kitchen sink for drinking and fridge water, fed by softened water. Salt is removed, and the taste is much better than the softened water, even though the whole house is carbon-filtered.
It sounds expensive, but ordering the proper equipment online is far more affordable than calling an expensive water guy.
Good luck with whatever you decide.
