Results 1 to 2 of 2
Thread: intermittent heating element outage
Hybrid View
    DIY Junior Member alisa53's Avatar
    Jul 2012
    Virginia
    Unhappy intermittent heating element outage
    Hi - we recently installed a Marey GA16LP propane unit for an outdoor shower. We have it installed with an inline filter. It was working beautifully for several weeks, using water from a 1550-gallon cistern that was filled with chlorinated municipal water. This week we finally got our well in and routed the water to the outdoor shower. It was working fine until today, when the heating element began to intermittently shut off. All propane connections look good. Logic says it has something to do with the well water, but we assumed the good inline filter would take care of any residue. Anyone have a problem like this, or know of anything else we should be checking?
    DIY Junior Member Mr Cuddles's Avatar
    Aug 2012
    S. Ontario
    I would check to see what the system says the water flow is first. Then make sure it meets the manufacturer's specs. Other issues could be gas pressure. I have never worked on a Marey before but most newer models rely on a balanced gas pressure for proper air/ gas mixture, if the gas pressure fluctuates too much the burner could cut out due to a poor flame signal.
    Also make sure the intake air filter is not plugged up if there is one...
  1. heating element for Frigidaire oven
    By rburt5 in forum Electrical Forum discussion & Blog
    Last Post: 03-06-2011, 01:21 PM
  2. Power Outage Question
    By brianjcollins in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-06-2010, 08:58 AM
  3. Thermostats : Dual Element in a Single Element Water Heater
    By Synicasm in forum Water Heater Forum, Tanks
    Last Post: 11-09-2009, 01:35 PM
  4. Single element thermostat on dual element heater
    By garycase in forum Water Heater Forum, Tanks
    Last Post: 07-31-2009, 04:51 PM
  5. Replace heating element AO Smith ProMax
    By john_k9jgs in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-03-2005, 07:43 PM
