Results 1 to 10 of 10
Thread: Noritz N-069M problem
    DIY Junior Member muser3's Avatar
    Jul 2012
    Texas
    Default Noritz N-069M problem
    Hello everyone, This is my first post also.
    I have Noritz model N-069M. The tankless heater has worked well for a few years but recently it starts right up as it should but after a couple of minutes the water begins to get cooler, then cold. After turning the water off completely and restarting, the water will be warm for a while, then get cold again.
    The remote panel shows no faults and I have cleaned the filter.
    Any comments will be welcome.
    Jul 2012
    Texas
    Since there are no replies I wonder if:
    1. It's time to think about a new heater
    2. The solution is in another post and I didn't notice it
    3. The problem is so unusual that no one has an idea about how to remedy it
    Any ideas out there?
    In the trades Dana's Avatar
    Jan 2009
    Have you called the local Noritz distributor for technical help or recomended installers for de-bugging it?
    It's unusual to have this sort of behavior without spitting a code, but it doesn't sound like an unresolvable problem. Unless the thing is approaching 2 decades of service it will probably be worth fixing even if you have to pay a tech to do it.
    Jul 2012
    Texas
    Quote Originally Posted by Dana View Post
    Thanks for the help. I have not called anyone yet. I think the unit is less than ten years old so it should have lots of life left. It is in a home where we do not live full time but will someday return to. It gets used maybe 20 times a year but it should function properly.
    Jan 2009
    I agree that it should function properly, given the limited number of burner-hours you have on it- yours is barely broken in!
    Most Noritz water heaters DO function properly- they have one of the best reputations for reliability in the industry.
    DIY Junior Member davep1234's Avatar
    Feb 2013
    We had the same problem and have solved it with a yearly 45 minute white vinegar flush - there are many web sites explaining how to do it.
    DIY Junior Member Dee Brewer-Wooten's Avatar
    Sep 2013
    Texas
    I'm looking to buy the NORWITZ N-069M if someone is interested in selling. I need one ASAP. Please let me know. Thanks!
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    Quote Originally Posted by Dee Brewer-Wooten View Post
    Do you want a used one or a new one?
    Sep 2013
    Texas
    Either, but manufactured as close to 2004 would be great. It just really has to be that very same model number.
    Sep 2013
    Texas
    I did forget to mention that it must be a single vent LP gas powered water heater, which I am assuming is reflected by the model number, but not sure. --Thanks!
  1. Noritz fan seems to run alot
    By lifespeed in forum Tankless Water Heater Forum
    Last Post: 05-01-2012, 03:02 PM
  2. Noritz N 069 M starts without cause
    By dad353 in forum Tankless Water Heater Forum
    Last Post: 03-17-2012, 02:58 PM
  3. Noritz blues
    By noah677 in forum Tankless Water Heater Forum
    Last Post: 03-02-2012, 10:01 PM
  4. Noritz NR 111 SV
    By ewalker in forum Tankless Water Heater Forum
    Last Post: 01-03-2012, 03:12 PM
  5. Noritz Descaling
    By kamo in forum Tankless Water Heater Forum
    Last Post: 09-30-2010, 11:55 AM
