With all due respect: BACK THE TRUCK UP. Most of these systems require that the system be evacuated to remove air and non-condensibles, BEFORE opening the king valve to let the charge out of the condensing unit into the system. The factory charge is APPROXIMATE for x many feet of line, but you must set the super-heat or sub-cool using gauges. This is NOT plug and play or DIY.
