that sensor tells it how much water was used, and when to regen. i have one of those crappy units as well. try unplugging the sensor and plugging it back in again. the sensor they use does not fail that often. it is called a hall effect transistor. it reacts to a magnetic field. the connection may be corroded. had that happen to me as well. that was the fix that kept it going.
