Results 1 to 5 of 5
Thread: Rough drain PVC wall opening heights - slope
    sea-bee chuck b's Avatar
    Jan 2011
    levering, michigan
    Default Rough drain PVC wall opening heights - slope
    Installing a new DWV system (sch. 40 pvc) in my small cottage. Need to know the centerline of the rough drain heights (stub outs) for the:
    kitchen sink (and is there a separate height for the disposal line), the bathroom sink, and laundry.
    Also curious about technique of sloping both 3" and 2" sch. 40 pvc drain lines to the septic in the crawl space under the floor. Doesn't sloping the drain lines (which I know one has to do) "cock" the closest flange...or do you rely on a bit of flex to accomodate this slight drop - also with a longer run of kitchen drain pipe as well. Using 2" for tub with shower, laundry, and 4" to 3" for the toilet closet flange.
    Thanks for the help. Also, would you work from the Septic line toward the individual drains, or start with the new drain lines and then connect to the septic line. No drains there at all - removed.
    DIY Member wallskev's Avatar
    May 2009
    North Carolina,USA
    Default Plumbing Rough In Dimensions
    Sinks
    Drain Pipe: About 16-20 inches above floor. We will consider the drain pipe to be a vertical centerline.
    Supply Lines: Two holes. One hole is 4 inches to the right of centerline, another hole is 4 inches to the left of centerline Vertically, both holes are about 2-3 inches above the drain pipe.
    Placement of Sink: Vertically, the sink should be about 31 inches above the floor. Measure up to the rim of the sink.
    Toilet Rough-In Dimensions
    Supply Line: One hole, between 5-10" above the floor. Off-set this supply line from centerline by five inches.
    Discharge Hole: Off-set this hole from the wall framing by 12 1/2". Consider this hole to be centerline.
    Tub Rough-In Dimensions
    Shower Stub: 80". This is the highest point, the place where the shower nozzle will go. We will consider this centerline.
    Tub Spout/Stub: 26"-35" high. Place this on the centerline.
    Faucets: 10" above tub spout. Place one faucet 4" to the left of centerline and the other faucet 4" to the right of centerline.
    Drain: Place drain on centerline. Total opening for drain access can be between 10"-14" off-set from framing, and 6"-8" wide.
    Hope this helps.
    Kevin
    quiote; Tub Spout/Stub: 26"-35" high. Place this on the centerline.
    That will put the faucet between 3 and 4 feet above the floor. I have NEVER installed a tub faucet that high. THe spout is usually 6-8 inches above the tub and the valve 6-8 inches above that. A shower valve will be mounted about 3-6" above the floor.
    Nov 2010
    Maine
    I like to read either the directions or the cut sheet that comes with the fixtures. When you guess at it you quite often wind up having to use non standard length supplies and tail stocks or waste time fiddling with things.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    Quote Originally Posted by chuck b View Post
    Drain fittings have the 2% (1/4 inch/foot) angle built in to them. I would assume the closet flange does too. Regardless, with plastic pipe, joints can be "bent" enough before they set up...
    You want the pipes to be straight (no high or low spots) -- not "flexed".
  1. Help - Tub / shower install 58.5" rough opening!!!
    By cleaver in forum Shower & bathtub Forum & Blog
    Last Post: 02-15-2012, 05:46 AM
  2. Garage Door Opening Wall 2x4 or 2x6?
    By Lakee911 in forum Remodel Forum & Blog
    Last Post: 08-11-2009, 01:50 PM
  3. Toilet Drain - Rough-In Distance from Wall
    By hijacker in forum Toilet Forum discussions
    Last Post: 03-21-2008, 06:39 AM
  4. Rough Opening for Door
    By nelsonba in forum Remodel Forum & Blog
    Last Post: 11-21-2007, 03:36 AM
  5. Rough in opening about 9 inches>
    By bullsnbears in forum Toilet Forum discussions
    Last Post: 09-28-2006, 03:15 PM
