No regeneration?
Martinf55
Brampton, ON.
Ive had my Fleck 3600sxt for a month now and it hasn't regenerated yet. I have it set to regenerate every 14 days or earlier if needed. Can't figure it out?????
Tom Sawyer
Maine
Is it drawing brine ? Have you cycled the valve and checked that you have suction at the brine line?
ditttohead
Water systems designer, R&D
Ontario California
3600SXT? Well, I assume you mean the 5600SXT since the 3600 was never available in electronic form, and it was discontinued about a decade ago...
A common problem with newly installed systems is the turbine in the meter can get a piece of teflon tape, debris, etc inside of it. Do you see the meter indicator flashing when water is flowing?
ditttohead
Ontario California
On the SXT screen, right hand side, you should see a water drip (not the faucet) and it should blink when you turn on water inside the house. The system must be in service (not regeneration). I assume your system is a metered 5600SXT. Check that first and let us know what you find.
Martinf55
Brampton, ON.
Have to wait for initiated regeneration to stop. Want to see it go through stages. I'm pretty sure that water drip flashes.
