Results 1 to 6 of 6
Thread: No regeneration?
    DIY Junior Member
    Jun 2012
    Brampton, ON.
    Default No regeneration?
    Ive had my Fleck 3600sxt for a month now and it hasn't regenerated yet. I have it set to regenerate every 14 days or earlier if needed. Can't figure it out?????
    Nov 2010
    Maine
    Is it drawing brine ? Have you cycled the valve and checked that you have suction at the brine line?
    Jan 2012
    California
    3600SXT? Well, I assume you mean the 5600SXT since the 3600 was never available in electronic form, and it was discontinued about a decade ago...
    A common problem with newly installed systems is the turbine in the meter can get a piece of teflon tape, debris, etc inside of it. Do you see the meter indicator flashing when water is flowing?
    DIY Junior Member
    Jun 2012
    Brampton, ON.
    Did a manual regeneration and BW flashing then stopped when time countdown started.
    Jan 2012
    California
    On the SXT screen, right hand side, you should see a water drip (not the faucet) and it should blink when you turn on water inside the house. The system must be in service (not regeneration). I assume your system is a metered 5600SXT. Check that first and let us know what you find.
    DIY Junior Member
    Jun 2012
    Brampton, ON.
    Have to wait for initiated regeneration to stop. Want to see it go through stages. I'm pretty sure that water drip flashes.
  1. Can I take a shower or use water during regeneration?
    By martinf55 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-09-2012, 06:22 PM
  2. Black water after regeneration....
    By Steve38 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-14-2011, 12:57 PM
  3. No regeneration - turbine problem?
    By SteveW in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-08-2011, 08:16 AM
  4. Frequency of regeneration
    By TWEAK in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-16-2010, 07:54 AM
  5. Water Softener Regeneration
    By jbschaefer1 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-08-2006, 04:52 PM
