Results 1 to 3 of 3
Thread: SLC AC Repair
Hybrid View
    In the Trades tingeyplumbing's Avatar
    Dec 2011
    Salt Lake City, Utah
    Default SLC AC Repair
    In the middle of the summer, when temperatures reach near the mid to high nineties everyone of us realizes how much we need air conditioning, because it seems to be the only thing that can make these temperatures bearable. We all want a constant, comfortable temperature that can help us relax at home or concentrate and be more effective at the office. However you should pay attention to the air quality in your home and take care of your family's well being. That's why you should call a Salt Lake City AC repair company just to make sure everything is fine.
    For example, indoor air filters can reduce some airborne irritants and they also reduce the levels of pollen. Filtration of air can alleviate allergies like hay fever, asthma or pet allergies. Choosing the right Salt Lake City Utah AC repair company also has its benefits: the latest systems and equipment are highly efficient in terms of energy usage, the customer has financial benefits and the environment is protected.
    When it comes to Salt Lake City AC repair the costs can range from a simple fee of showing up and changing out a fuse to major repairs like replacing the compressor, so be careful when you are choosing the company. If you want to save some money on major repairs the best solution is regular maintenance. It is a recognized fact that a regularly serviced air conditioning unit will have a far longer lifespan, will have higher performance and be more energy efficient than a unit which doesn't receive it. The best time to have your AC services is in the Spring, just before the sizzling summer heat wave. This way you can be sure it won't stop working when you need it the most.
    Replace the air filters if they are disposable or clean them by using a vacuum cleaner and then wash them under warm soapy water. A thoroughly cleaned air conditioner will operate at maximum efficiency. However the best thing would be to employ a Salt Lake City Utah AC repair company to service and maintain your system.
    If the AC stops working then it could be an electrical or mechanical problem on the HVAC systems: refrigerant leaks, dirty condenser coil or unit, dirty evaporator or cooling coil, or burned out (or hard-starting) compressor motors. If your air conditioning or heat pump system has completely lost cooling capacity or if it plain won't start then you might have a problem with the fan or the fan motor in both the compressor/condenser unit and in the air handler/blower fan unit.
    DIY Junior Member justintimeref's Avatar
    Sep 2012
    Mumbai, India
    A regular service and maintenance can easily help you to avoid the future problems with your air conditioner. Hence, make sure that you are getting it regularly serviced.
    Mar 2011
    Houston, TX
    My air quit working.
    What should I do ?
    I changed the filter and it did not help.
  1. Pex Repair
    By freedom in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2012, 12:57 PM
  2. slab leak repair - near old foundation repair with piers
    By carrotguy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-24-2010, 12:54 AM
  3. Tub Repair
    By jerome8283 in forum Shower & bathtub Forum & Blog
    Last Post: 10-07-2008, 06:57 AM
  4. Need help with repair
    By hondatech in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-30-2008, 06:58 PM
  5. ABS/DWV repair
    By Plumbcatastrophe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-13-2006, 08:48 PM
