Results 1 to 5 of 5
Thread: Mini split install questions
    DIY Member mar3232's Avatar
    Oct 2011
    Indiana
    Default Mini split install questions
    I'm not an HVAC pro but I would say I'm a semi-pro in just about everything else -- electrical, construction etc. and decided to do a small mini split in my bedroom (9000 btu).
    It will be a breeze to do the mechanical stuff and electrical -- the lineset will probably be less than 10 feet, where I plan on putting it. (probably be more like 6 feet or so).
    I've seen a few installs on youtube and it looks pretty straightforward but my question is this --
    If I'm careful and absolutely nothing is leaking, aren't these designed where a DIY'er can actually just connect the lineset and you can pretty much start using them without any additional refrigerant charging?
    I know a lot of you will say get a pro to check it out, but realistically? Guarantee the installation will be A1.
    I guess the hardest part are the bends in the lineset? -- do you guys use some sort of jig or tool for this?
    thanks.
    Plumber jimbo's Avatar
    With all due respect: BACK THE TRUCK UP. Most of these systems require that the system be evacuated to remove air and non-condensibles, BEFORE opening the king valve to let the charge out of the condensing unit into the system. The factory charge is APPROXIMATE for x many feet of line, but you must set the super-heat or sub-cool using gauges. This is NOT plug and play or DIY.
    Nov 2010
    Maine
    And, the charge on mini-splits is critical and weighed in. Gauges are useless too.
    Oct 2011
    Indiana
    Ok. Maybe if I do all of the mechanicals and Mr HVAC approves the install, I can save a few bucks (always on top of my mind). Even a run of 6 feet makes no difference eh?
    Oct 2011
    Indiana
    By the way if anyone is close to Indiana, have a nice Trane heat pump system available -- only 3 years use -- make me an offer.
  1. Mini-split system providers...
    By rfsmith48 in forum HVAC Heating & Cooling
    Last Post: 05-10-2012, 09:09 AM
  2. LG Mini-Split Heatpump system - Operating temp?
    By yds in forum HVAC Heating & Cooling
    Last Post: 12-08-2010, 02:21 PM
  3. mini split heat/cool system
    By DIY in forum HVAC Heating & Cooling
    Last Post: 09-01-2010, 10:41 AM
  4. Mini Split ducting inside walls
    By bigwooo in forum HVAC Heating & Cooling
    Last Post: 09-08-2009, 05:54 PM
  5. Mini split toolkit
    By Noth Jersey in forum HVAC Heating & Cooling
    Last Post: 01-26-2009, 01:43 AM
