Results 1 to 8 of 8
Thread: Water Softener & Options Recommendations
    DIY Junior Member Courtney's Avatar
    Jul 2012
    Dayton, Ohio
    Default Water Softener & Options Recommendations
    A summary of the facts:
    • Judging from the deposits in and on sinks, toilets, faucets, and tubs, I have pretty hard water
    • Recent water report: http://www.hhoh.org/images/huber/pdf...y2012final.pdf
    • Household of 3, 1 bath, 1 half bath
    • Previous house owner had a softener (took it with them), so a closed loop already exists for an install. I plan to do the install myself. Plumbing experience = water heater install
    • Existing piping is ĺ copper
    I spent several days looking into this about a year ago, and at that time, had pretty much decided on a 32000 or 40000 grain capacity Fleck 5600 or 5600SXT. At this point, I canít recall what percentage of that decision was based on research vs. a sales pitch.
    I plan to buy from Ohio Pure Water, mainly because they are right around the corner. Based on the information above, can someone recommend a system and options?
    http://www.ohiopurewater.com/shop/cu...me.php?cat=173
    I'm a pretty competent DIY'er.
    Thanks,
    Jan 2012
    California
    I did not see a hardness result. Get a Hach 5B test kit and give us an accurate hardnes test. The resut of the numbers look decent. A standard 56SXT is perfect for your application, the size is what is in question. We need to know the hardness to determine the correct size.
    Jul 2012
    Dayton, Ohio
    Thanks for the info. I ordered it online straight from Hach. I'm assuming it'll be here sometime this week. I'll report back with results.
    Thanks,
    Courtney
    Jul 2012
    Dayton, Ohio
    Got the Hach 5-b test. It took about 17 drops. Pretty hard.
    DIY Senior Member F6Hawk's Avatar
    Mar 2012
    Alaska
    Assuming 60 GPPPD, you could get a 48K, set it for 8 # of salt, and go 10 days between regens, using about 438 lbs of salt per year. Or set it for 6 # of salt, go about 9 days between regens, and use about 365 lbs of salt per year.
    Go with a smaller 32K system, and set it for 8#, and get about 7 days between regens and 417 lbs of salt per year. At 6# per regen, 5-6 days between regens and 438 lbs of salt again.
    If you pay a little more now for the bigger system, you will save salt over the long run, as well as put less waste salt out into the environment.
    Jul 2012
    Dayton, Ohio
    The first time I performed the test, I was a little rushed. I've performed it twice since and had to use about 23-24 drops each time before the solution turned blue. Not sure if these new results change anything...
    Any comments about the valve connection, resin or media gaurd options?
    http://www.ohiopurewater.com/shop/cu...cat=179&page=1
    Thanks,
    Courtney
    Nov 2010
    Maine
    I think that you made a wise choice. Media guard you don't need, std resin is good and the valve connection is OK also. Good luck
    Jan 2012
    California
    18x33 brine tank uses more speace, but is definetly better. The Media guard is a great option, but they are prone to fail if they are not set up correctly and should be changed every 3-5 years. If you use the media guard, be sure the system has a 4 or 4.5 GPM DLFC button installed. The plumbing connectors are preference. You definetly want a bypass, the website doesnt state if it comes with a bypass. be sure to get the one that matches your plumbing size to make installation easier.
  1. Well Filtering / Softener Recommendations?
    By JDM in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-17-2012, 09:10 AM
  2. Water softener & sediment filter recommendations?
    By chuck b in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-20-2011, 09:25 AM
  3. Low-end water softener recommendations?
    By stitch in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-15-2011, 10:19 AM
  4. Water Softener Recommendations
    By timk10 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-24-2009, 01:07 PM
  5. Hard AZ Water & Softener Recommendations ?
    By Gateway in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-06-2008, 03:46 PM
