Results 1 to 2 of 2
Thread: Concrete used to fill well higher than contamination level??
    DIY Junior Member Ronemuzz's Avatar
    Jul 2012
    southern oregon
    Default Concrete used to fill well higher than contamination level??
    Long story but County dug a replacement well for one they had disrupted while removing a dam. Water tested as highly contaminated with aluminum, arsenic, sodium, boron, among others, to a level that the only treatment alternative would be whole house RO. Well driller thought he might have punched through a basalt layer and proposed adding concrete to raise the bottom. After doing so, quality improved to a fairly easily treatable level (iron, manganese, hardness). Is this an accepted practice? If well is used at a high volume (irrigation), would the original contaminates be able to sneak through the plug? Would you use this well for your drinking water?
    Moderator valveman's Avatar
    Mar 2006
    Cementing between different water zones is a common practice. If properly installed it works very well. However, just because of the proximity of those nasty chemicals, I might have a test done every once in a while.
  1. Benseal Contamination in well water
    By CelticRedneck in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-08-2011, 07:51 AM
  2. Flange Ringer and concrete level question
    By gopokes65 in forum Plumbing Forum Discussion & Blog
    Last Post: 05-28-2011, 02:32 PM
  3. how does contamination occur?
    By rbig in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-10-2011, 07:57 PM
  4. Toto Ultimate bowl level low after replacing fill valve
    By ned in forum Toilet Forum discussions
    Last Post: 12-25-2007, 05:42 PM
  5. How can I level a concrete porch?
    By dukes in forum Remodel Forum & Blog
    Last Post: 10-08-2007, 09:39 AM
