Results 1 to 3 of 3
Thread: well size?
    DIY Junior Member derek28's Avatar
    Jul 2012
    Indiana
    Default well size?
    I have some question about well size, I currently have a 2" well with a jet pump and over the last 2 years the water psi has been getting worse when running 2 or more things in the house and i cant deal with it anymore. So i called a well driller and he said that the screen is probably getting plugged up so i asked him about some pricing on a new well and its only $200 more for a 5" well vs a 4". What are some advantages of a 5" well compared to a 4"? And what about pump hp is 3/4hp better than 1/2hp??? The reason im curious is im planning on adding on another bathroom and maybe next year building a pole barn (if she'll let me) and i want to make sure there will be enough water if im washing my truck and the wife is doing dishes and the sprinkler is going in the garden and my daughter flushes the toliet. lol I just want to have enough water is a 4" going to be that much better than my current 2" or should i go with a 5"? He said that he's drilled wells around me and that 125' would probably be the depth so what hp would be best even though the addition and the barn are not there yet? And if I do over size the pump will it hurt anything until the barn gets built?
    Jul 2012
    Indiana
    After reading alittle on here maybe a 4" with a csv is what i need?
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    For 200 more I would go with the 5”. There are a lot more options available and a lot less problems in the long run with 5”.
    A HP, 10 GPM series will do 12 GPM at that depth. That should be plenty of water. But the beauty of a CSV is that you can install as large a pump as you want, and still use it like a small one without hurting anything.
  1. Manifold size vs Supply size
    By Garfield in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-18-2011, 12:16 AM
  2. What size pex should i run?
    By bigal0043 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-16-2010, 04:16 PM
  3. Pump Size, Pipe Size, CSV location????
    By fausdick in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-20-2009, 05:40 AM
  4. Size a faucet to the room size?
    By chrisexv6 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-06-2008, 07:09 AM
  5. Tub size 14.5 or 16?
    By duct tape pro in forum Shower & bathtub Forum & Blog
    Last Post: 06-02-2007, 09:30 AM
