Results 1 to 15 of 31
Thread: Cost to install new valve - galvanized steel to copper?
Hybrid View
    DIY Member Henry Ramsey's Avatar
    Jun 2006
    Houston, Texas
    Question Cost to install new valve - galvanized steel to copper?
    Hey all,
    I'm in a 40+ year old condo in Houston, Tx and we have galvanized steel water pipes.
    I plan to update our hallway tub/shower and I have to change out the valve body too.
    For this I obviously need to hire a plumber. My question is ass-u-me-ing that all things go right
    how much should I expect to pay? $200-300? Is there anything special the plumber should know about
    for this type of job? The condo shares cold water and we have a common hot water heater too.
    The current valve body is made by Sterling and has integral stops. The stops leak when turned and according to Stanco plumbing supply they cannot be replaced(sterling must have stopped making them since 2007 when I replaced stops and stems in my shower which is the same parts) only rebuilt and that would take over a day.
    Our condo has a common water shut off for 15 units not local per unit so I cannot take the stops out without needing to shut off my unit plus 14 others for as long as the stops are remove.
    My HOA will not allow this and I'd be persona-non-grata with my neigbors if I did.
    Therefore I have no choice, but replace the valve. I hope to install a valve that equalized pressure and temperature since we sometimes have problems with both.
    Any advice,
    Henry
    Money Talks? All it ever says to me is "Goodbye!"
    I don't think you have much choice but to make arrangements to shut the building water down if you want to replace that valve.
    Pricing is really tough as all areas labor rates, building permits, etc. are different. Assuming this needs a permit and will be inspected, that by itself could add hundreds. If in the process of removing the old one, the galvanized piping is found to be in too bad of a shape, it could cost LOTS more, but often, the condo association owns the 'infrastructure', and would have to pony up that repair cost.
    Galvanized piping is a disaster waiting to happen. Touching it is fraught with potential pitfalls.
    Jun 2006
    Houston, Texas
    Thank you for the fast reply. Shutting off the water for a short time yes. Our policy is 24 hours notice and is fairly liberal. For a whole day or more, no. We had a water main break up the road last year and our whole neighborhood was without water for about 3 days off and on. People hated that (I'm sure COH water got many angry complaints) and we have neighbors with small children plus it's summer in Houston where temps can soar to 100+ in July and August.
    I guess I'll have to call a few places and see what they quote me. Maybe it'll be less than I'm thinking.
    I don't know about permits being too much. I rebuilt my own shower including a Schluter Kerdi drain, etc. I mudded my own shower and did it by the Kerdi book. I pulled a homeowners' plumbing permit and passed fine. It was about $60 total, IIRC.
    If not for the stupid issue with the valve stops I'd leave it be. The pipes are in decent enough shape. Is it possible to just put in ball valves below the valve body or something to compensate for the stops being bad? I guess that's as bad as changing out the whole valve? The HOA doesn't own the pipes that feed our individual bathrooms and kitchen per our HOA documents. We are responsible if there are any leaks or problems that means.
    Our HOA has had some galvanized pipes replaced with copper and a plumber changed to copper for the connections of both hot water heaters so I'm thinking of calling on him. He replaced a hot water heater and the city inspection passed.
    At least he has experience with our HOA pipes. It's just I have to pay with a CC and he's a one-man business and he
    may not accept CCs. I also have a friend who has a reliable GC she used to do work on her home. Perhaps he might
    have a reference.
    Galvanized is messy to work with as you need to go back to the last threaded connection and then build back up from there. Hopefully, you have an access panel. A ball valve can be installed in the process of rebuilding things. As you've found, a new valve with stops may not be much help on a later repair since they may no longer work. They ARE handy, though, when building things back up since you can shut them off then work on the rest...this might, depending on the configuration, let you turn the water back on quicker but not if you're putting in ball valves.
    Jun 2006
    Houston, Texas
    Yeah, I'm in for it when it comes to the galvanized pipe. I hope it'll work out. The water pipes come through the floor from the laundry area right below I think. I think they also share a common drain pipe and vent.
    I think I'm going to have to start with the plumber who has done work around here. He has good familarity with our pipes since he has also worked for several of my neighbors and the HOA common pipes too. He may even have knowledge of what to do since our units are cookie-cutter identical. I think he may have even replaced someone else's valve though the
    neighbor of that unit complained of rust and sludge in their water right afterwards too. A taste of cutting oil in their water too, but somehow I'm skeptical of that...
    I hope to build in an access panel where none exists; there is a closet right behind there the valve body is so the access panel can be discret. I also hope to do any plumbing whilst I have the walls torn down to retile.
    The current tile is puke..err avacado green circa 1971 or so and needs to come out.
    The tub with the appliques is in the same bathroom, btw.
    I had great success with Kerdi in my other shower and I'll be using it again here.
    I'm just having some supply problems buying it. Schluter isn't making it easy for consumers to buy and have a warranty (I wish someone would sue them for antitrust). The other shower was a walk-in 30x30 and I built it from mud bed up (I even had it inspected and passed) to this should be a breeze by comparison except for this stinking valve.
    In that shower I just left the valve body alone and replaced the stems and stops which were available back then. I even changed the valve seats after some mild problems that the seat wrench was hitting the back wall of the valve body before it was wide enough to engage the seat. I ended up using a wide flat screw driver instead.
    Jun 2006
    Houston, Texas
    OK. Forget actual pricing and assume the building permit is low cost. My homeowner's plumbing permit in 2006 was $17 and the regular building permit for the shower rebuild was $35 w/a est. valuation of $1400 for the job.
    I found my permit record earlier tonight.
    Let's ass-u-me the pipe is intact and can be re-threaded with relative ease and a union fitting put on to connect a new valve body. Our HOA has had a few sections of the main-feed hot and cold water lines which feed two buildings replaced and none have had any serious complications during those repairs. Several times the HOA had galvanized replaced with same and others there were union fittings and copper bridged in.
    Assume the pipes to my shower/tub are at least as intact. How long should a competent plumber take to do a replacement of the valve body under normal circumstances including putting in the union fittings, sweating copper, etc? This will help me figure out the labor cost at least get me in the ballpark. Would three-four hours be outlandishly long or short time?
    Yakima WA
    Considering your plumbing is a disaster to begin with, and not being able to see the job site, it is virtually impossible for anyone hundreds or even thousands of miles away to give an educated guess on what you want to know, and by the way, this is not a normal job. The best thing for you to do is to get at least 3 estimates from local licensed plumbers who can inspect the work site in person and see what will be involved. Most condo associations require a licensed plumber to do plumbing, and licensed electricians to do electrical work, etc.. You also need to realize that the time will include travel to and from the shop, as well as the possibility of requiring more than one person.
    Jun 2006
    Houston, Texas
    OK. I'll have to find someone to inspect the issue once I actually get into the shower and take off the wall. I had hoped to get a general idea of the cost before I begin. Obviously, not going to happen though.
    The HOA generally uses licensed/insured workers, but has no such restriction on what each homeowner does with his or her own unit's plumbing. Many even use handymen even for plumbing however illadvised that would seem to be.
    I will however look for someone who is a qualified plumber.
    Houston may be different (Texas seems to be that way with things!), but in most parts of the country, in a multiple family dwelling, the homeowner cannot pull a permit and perform certain work. While I can actually do hvac stuff legally in my condo, I cannot do electrical or plumbing work - it must be done by a licensed workman. IOW, stuff you could do in a single family dwelling yourself, you cannot do in most places if it's a multiple family dwelling.
    I'm not sure how many plumbers still cart around a pipe threading machine. As mentioned, taking threaded piping apart can lead to problems not readily apparant.
    WIth the wall out and full access, it may only be a few hours work. That could turn into much longer. You may end up with say the cold line being still good, and the hot one all rust inside, or both could be bad, or both good. You won't know until it is torn apart. It can look great from the outside, but you won't know until you start to take it apart (unless it is really bad already).
  1. Galvanized Steel Duct for Dryer Ducting
    By chefwong in forum Remodel Forum & Blog
    Last Post: 09-21-2010, 06:25 AM
  2. Stuck galvanized steel elbow
    By mrspaceman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-27-2008, 07:00 AM
  3. Cast iron vs galvanized steel.
    By duffers in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-08-2007, 01:18 PM
  4. Galvanized Steel Plumbing Question
    By RebeccaWard in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-12-2006, 06:14 AM
  5. Removing galvanized steel pipe from cast
    By jdkimes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-20-2006, 09:10 PM
