Kyle Dudley
im trying to pressurize the water from my reservoir so i use in my grow room. right now im pumping the water into 5 gallon jugs and carrying them upto my room,
my idea is to use a sump pump(float switch disconnected) to a smal 10-20 gal pressure tank controlled by a pressure switch, and them from there to my room that will have multiple faucets/spickets
theoretically it would be a small scale well system but instead of the pump in a well it will be in a 35Gal reservoir
will this work?? will a sump pump be strong enough to work with the setup i described?and how powerful should the pump be(horsepower wise?)?
