Results 1 to 2 of 2
Thread: pressurize RO reservoir water? need help
    DIY Junior Member Kyle Dudley's Avatar
    Jul 2012
    Michigan
    Default pressurize RO reservoir water? need help
    im trying to pressurize the water from my reservoir so i use in my grow room. right now im pumping the water into 5 gallon jugs and carrying them upto my room,
    my idea is to use a sump pump(float switch disconnected) to a smal 10-20 gal pressure tank controlled by a pressure switch, and them from there to my room that will have multiple faucets/spickets
    theoretically it would be a small scale well system but instead of the pump in a well it will be in a 35Gal reservoir
    will this work?? will a sump pump be strong enough to work with the setup i described?and how powerful should the pump be(horsepower wise?)?
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    I don't think plants want to live off of r/o water.. i think they may need some minerals in the water. not sure though because I don't grow pot, er, um,... plants and flowers and such. just a thought though. if you really want to use r/o water, why not just run a longer tube up to your room? the r/o faucet would not be able to make a lot of pressure before it shut off and went down the drain as waste water. the r/o system should be able to pump about 25 feet of 1/4" tube, so just run a line to where you want it and then use a shutoff at that point. easy peasy.
  1. well water tank storage ---would like to pressurize with compressed air
    By corvettejohn in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-30-2011, 02:38 PM
