Results 1 to 6 of 6
Thread: Check Valve or Ball Valve to HOLD PRIME
    DIY Junior Member Mike Pastorelli's Avatar
    Jul 2012
    Florida
    Arrow Check Valve or Ball Valve to HOLD PRIME
    I have decided on a different course with my well.
    I will be using a 1/2 HP FLOTEC pump and I will be just using my well for irrigation.
    I dont want to install a check valve to hold my prime. Can I install a ball valve?
    So once I get it her flowing and then when I finish watering, I would just close the ball valve and pull the plug on the pump. This should hold the prime, correct? This will work?
    Mar 2011
    Houston, TX
    You could do that but you would want it on the input of the pump unless you have a pressure cutoff switch on the output and before the Ball Valve input.
    Or turn the power off before closing the valve.
    Don't pay someone to do a job fast, when you can do a half-fast job yourself.
    Dec 2009
    northfork, california
    Why make it so hard? Use a check valve.
    Mar 2011
    Houston, TX
    Quote Originally Posted by ballvalve View Post
    That would be easier.
    I thought that you would favor a Ballvalve for some reason.
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    "I thought that you would favor a Ballvalve for some reason. "
    lol
    Dec 2009
    Funny. All valves have their issues, but a ballvalve not regularly used gums up and might not be useable at all. Disc valves are nice because they are balanced to the pressure. A good gate valve is still hard to beat.
  1. Pump Won't Prime or hold prime
    By PAmom1991 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-31-2011, 07:09 AM
  2. Swing Check vs. dual check vs. double check valve
    By colbymom in forum Plumbing Forum Discussion & Blog
    Last Post: 05-10-2011, 01:19 PM
  3. Sump pump ball check/backflow valve.
    By cjskier in forum Plumbing Forum Discussion & Blog
    Last Post: 09-04-2010, 11:21 AM
  4. Combo ball valve/check valve for ejector pump...
    By hhcibtpaun in forum Plumbing Forum Discussion & Blog
    Last Post: 06-17-2009, 12:27 PM
  5. Autorol 255/400, no ball in check valve
    By copeda in forum Plumbing Forum Discussion & Blog
    Last Post: 01-29-2008, 11:48 AM
