Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
Thread: "Running Water Sound" coming from behind the walls - What could be the cause?
  1. #16
    Jul 2009
    North Vancouver, BC
    Is AP the same as Synko Joint. It also shrinks and locks. I checked my patches from the other day and found a lot of fibers from the Mapei Fleece where raised. I tried double hitting it and that was a mistake. The first round I let the Joint Compound set up over night and had much better results.
    You just can't rush a drywall job!
    JW
    "When it's Perfect. It's good Enough." - John Whipple ...................... Q: Who are the Top Ten Bathroom Designers for 2010-2012..? ANSWER
    Contact Info: Email jfrwhipple@gmail.com Phone: 604 506 6792 Alternate Email: info@byanydesign.com
  2. #17
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    I just googled Synko Joint. Close enough. Anything that requires air to dry vs *hot mud* compresses in nature as it dries --- pulling the paper/mesh tight onto the joint/mud.
    I've learned so many tricks over the years. If you are getting grain raise * whether it be from drywall paper, taping joint paper, etc*, after the 1st coat or even before - I hit it with a thin coat of shellac based primer - BIN red- and that does the trick.
  3. #18
    Jul 2009
    North Vancouver, BC
    So I spoke with my plumber yesterday and it turns out this local company can only pull a new line from the City Connection to the house. As far as in the home they can not. So out comes the sawall! lol
    Ian starts today. Out with the old and in with the new.
    JW
  4. #19
    Jul 2009
    North Vancouver, BC
    So my plumber found two leaks in the original plumbing lines that ran through under the floors. He needed to pull back the carpet and open up both subfloor and drywall. The leaks have been fixed and the sound of running water stopped.
    What a nightmare and all that water could not be good for the foundation of the home. It's time to break out the drywall tools and get this repair finished up!
    JW
  1. Traps in Walls: "Can't" vs. "Shouldn't"
    By speede541 in forum Plumbing Forum Discussion & Blog
    Last Post: 03-08-2011, 11:33 AM
  2. "chugging" sound when tank fills
    By blu_ize317 in forum Toilet Forum discussions
    Last Post: 02-01-2011, 03:38 PM
  3. Intermittent Low Pressure, "Lagging" Sound Well Pump
    By wcp in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-27-2010, 11:01 AM
  4. "cricket" sound after turning off shower
    By mav91 in forum Shower & bathtub Forum & Blog
    Last Post: 08-18-2009, 06:20 AM
  5. "Oily smell" coming from one hot water tap
    By MikeW888 in forum Plumbing Forum Discussion & Blog
    Last Post: 09-15-2008, 02:01 AM
