Results 1 to 2 of 2
Thread: Tee with left-hand inlet for kitchen?
Hybrid View
    DIY Junior Member fbacher's Avatar
    Jul 2012
    Texas
    Default Tee with left-hand inlet for kitchen?
    We are replacing kitchen cabinets, the wall is open and I'm tired of unplugging my baffle-T. I want to change to two drain lines with separate traps, etc. My choices seem to be to add a branch vent and horizontal drain OR to use one of these double tees that are at right angles to each other http://dar.proflo.com/darmanager/Que...YPE=ZOOM_IMAGE. All openings in this tee are 2".
    The existing waste line is 2" and the vent is 1.5". If I understand the UPC correctly I can have both basins drain into the above double-Tee via separate traps and 1.5" drain lines. Exit from the tee will be 2".
    Does this sound reasonable?
    A picky inspectore might turn down that fitting because the "left hand" opening does not have a sweep to the connection. The right hand one does. In any case, that might be the last fitting I would use because there should be many ways to do it better.
  1. Ultramax II, left or right hand trip lever in small powder room?
    By greyhound1 in forum Toilet Forum discussions
    Last Post: 07-04-2012, 04:29 PM
  2. Are there any decent Solid Brass Kitchen faucets left?
    By Firemark in forum Plumbing Forum Discussion & Blog
    Last Post: 10-25-2010, 02:00 PM
  3. Installing kitchen faucet with totally separate hand spray?
    By eeka in forum Plumbing Forum Discussion & Blog
    Last Post: 09-30-2009, 06:14 AM
  4. Kitchen faucet - left to right reversal of spray
    By Optiker in forum Plumbing Forum Discussion & Blog
    Last Post: 07-28-2008, 07:15 AM
  5. Left-Hand Drain Installed for Right-Hand Drain?
    By Czarcasm in forum Shower & bathtub Forum & Blog
    Last Post: 02-26-2008, 05:33 AM
