Results 1 to 13 of 13
Thread: Need review of a rough plumbing diagram
    Cleveland Guy ClevelandGuy's Avatar
    Jul 2012
    Olmsted Twp, Ohio
    Default Need review of a rough plumbing diagram
    Can someone review the attached rough plumbing diagram. Let me know if my pipe sizes are ok, and check my venting. I have no clue how to properly vent, especially with 2 bathroom sharing a wall. Any other suggestions would be great!
    This is for a single story ranch style cottage with a crawlspace with the main drain going horizontal to a septic tank.
    Any help/advice is greatly appreciated
    If you intend to acutally install it the way you have drawn it, you are going to a LOT of extra work and expense. But it would be difficult to explain a different way and hope that you would understand and install it that way. You do NOT want to run 3" laterally and the reduce it to 1 1/2" for the sinks. And I would not run 1 1/2" to the sinks in the first place. The same thing with the 4" reducing to 2" for the tubs.
    Jul 2012
    Olmsted Twp, Ohio
    Your feedback is greatly appreciated. Could you suggest an easier way to layout this plumbing based on the constraints of the bathroom floor plan?
    DIY Member timf's Avatar
    Nov 2011
    Oregon
    And your vents on the toilets are wrong. They need to be downstream of the toilets rather than where you show them to protect the toilet traps from being siphoned.
    Tim
    Nov 2010
    Maine
    Quote Originally Posted by timf View Post
    Tim
    Toilet traps are designed to be siphoned and it makes no difference where the vents are except that that no part of the vent can be horizontal until it is 6" above the highest fixture served (the lav's)
    Nov 2011
    Oregon
    I didn't realize that. Thank you for the correction.
    The toilet vents are in a proper location, they are just connected horizontally.
    Certified Plumber Plumber1979's Avatar
    Jul 2012
    Ontario
    technically you dont have to ven your toilets if you have both lavs coming off like you do. its called wet venting
    Jul 2012
    Ontario
    thats not right either
    Nov 2010
    Maine
    Quote Originally Posted by Plumber1979 View Post
    Really? enlighten us please
    Nov 2010
    Maine
    Technically, he's in Oregon which is UPC so given the locations of the fixtures, he will have to individually vent the water closets. If Oregon was IPC then he could get rid of the toilet vents altogether.
    The vent cannot be horizontal until it is 6" above the "overflow" level of THE fixture, not the highest one.
    Nov 2010
    Maine
    No, that would be 6" above the flood level rim of the highest fixture served by the branch which in this case is the lav.
  1. Plumbing Diagram Help
    By bdaub in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-01-2010, 08:36 AM
  2. Basement bathroom rough in diagram feedback?
    By gerryuml in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-04-2009, 06:25 PM
  3. questionable rough-in diagram
    By magicalpig in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-19-2006, 07:06 AM
  4. Plumbing diagram software
    By prashster in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-10-2006, 08:28 AM
  5. Basement rough-in diagram
    By The_Project in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-03-2006, 08:11 AM
