Page 1 of 4 1234 LastLast
Results 1 to 15 of 46
Thread: Wire size, 3ph Delta, 120/240
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Default Wire size, 3ph Delta, 120/240
    Hey, anyone want to tell me the de-rating?
    The engineer has decided for reasons that I am not privy to, to spec a 125a 3pole on the switch gear to feed the sub panel I hope to be installing next week.
    He had originally drawn it with a 100a 3pole, and spec'd #1 cable.
    I'm going to need to pull 1/0, yes?
    I don't work a lot of three phase. Happily the switch gear is less than a year old, and there is a blank open for the new breaker.
    Not like some Frankenstein equipment in some damp basement.
    Electrician ActionDave's Avatar
    Feb 2009
    Colorado
    If you have less than three current carrying conductors in a conduit then you may not need to derate. For 3phase delta you would only have three. If you are under '11 code then there is a whole new set of rules concerning temperatures.
    310.15 is still the place to look.
    Jun 2007
    North Carolina
    A #1 copper THW conductor is good for 130 amps so I see no problem.
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by jwelectric View Post
    Three hots and a neutral (four conductors) does not demand a derating?
    I'm not complaining, the pull will be by hand, down 50' of 2", probably 3 x 90 degrees. With a #6 ground.
    Jun 2007
    North Carolina
    145*.80=116 (use the 90 degree column for derating)
    240.4(B) next highest OCPD = 125 amp
    I see no problem
    But it was a good question, it shows you are thinking
    Jan 2012
    Los Angeles, CA USA
    I see no problem
    I'll tell you one thing for sure. I don't want to buy 200' of #1, get the businesses in the building to understand that they are going to lose power over night, call the alarm Co and tell them the same, get some burly guy (likely the plumber I will be working across from on this one) to show up at 7pm, help me tug that crap thru, only to have the inspector at rough inspection ask me why I was keeping my head in my ass, and tell me that I had to do all that again, plus buy 200' of 1/0 on my own dime. A mistake like that and I'd pretty much be doing the rest of the damned job for free.
    I'd sooner put in some backstab outlets!
    Feb 2009
    Colorado
    Quote Originally Posted by Homeownerinburb View Post
    The neutral does not count as a CCC for derating if it only carries the imbalance of the load.
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by ActionDave View Post
    I keep forgetting. I do so little 3 phase.
    Dec 2009
    northfork, california
    I have 3 phase, 3 hots and a neutral . One wire is 277 or so volts to N - the other 2 wires are 240 volts to each other. Those 2 to neutral are 120 volts. This I assume is the 4 wire [ ground] 120-240 delta configuration. The POCO warns me not to try and start more than a 20 HP motor without a soft starter.
    Its a great system as one need not have the burden of transformers.
    But my question is why would the feed wires not be down sized as in all of the feeds to the 3 phase motors? Certainly the "stinger" high voltage wire could be smaller.....
    Jan 2012
    Los Angeles, CA USA
    Are you sure that it is not 208 to neutral?
    Feb 2009
    Colorado
    Couldn't be anything else.
    Feb 2009
    Colorado
    In a Delta service all three hots read 240V phase to phase.
    Jan 2012
    Los Angeles, CA USA
    That's what I had thought.
    Jan 2012
    Los Angeles, CA USA
    What color code is most common in your experience with this arrangement?
    Black, Red, and Orange for the wild leg?
    Feb 2009
    Colorado
    Black, orange, blue- three phase delta.
    Black, red, blue- three phase wye.
    I have heard that in California purple is used for the high leg.
  1. Wire size
    By MrBillyd in forum Electrical Forum discussion & Blog
    Last Post: 02-21-2012, 07:20 AM
  2. Ground wire size
    By Giles in forum Electrical Forum discussion & Blog
    Last Post: 02-17-2011, 11:41 AM
  3. breaker size for 12 gauge wire
    By whoazone in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2008, 05:02 PM
  4. Wire size question
    By jparrie in forum Electrical Forum discussion & Blog
    Last Post: 10-20-2008, 04:46 PM
  5. Intermixing wire size
    By Mr_Magoo in forum Electrical Forum discussion & Blog
    Last Post: 08-13-2008, 03:17 PM
