Results 1 to 6 of 6
Thread: New Fleck 5600 - HELP!
    DIY Junior Member Mike Larsen's Avatar
    Jul 2012
    Illinois
    Default New Fleck 5600 - HELP!
    I replaced an old water softener head (that finally died) and installed a brand new Fleck 5600 Metered head. When I called the distributor, I explained my entire setup and replaced everything except the 9x48 water tank and the brine tank (and I do mean EVERYTHING). I verified everything I needed was ordered and waited for everything to arrive. Long story short, I discovered I had no DLFC installed *AFTER* I ran my first regeneration. Did I lose my resin because there was on DLFC installed? The DLFC retaining clip WAS installed, just no DLFC behind it. There is a turbulator installed if that makes any difference.
    That being said, what's my resin situation and what size DLFC and BLFC do I need?
    -Mike
    You should have told them what size tank, and they should have asked you what size tank.
    Call them and tell them a 9" x 48" (1.0 cuft) and what type resin you have and have them send you what DLFC and BLFC you need for the valve they sold you.
    Before you call them, check the level of the resin in the tank is about 15" down from the bottom edge of the dome on top the tank; that's where the straight side starts to curve.
    In the dark, hold a light against the side of the tank away from the side you are looking at and look for the light to stop showing through when the light gets down to the level of the resin.
    If the tank wont allow light through it, then you have to take the valve off without breaking the distributor tube. Then the DT must be back down touching the bottom of the tank with no gravel etc. under it before screwing the valve back on. Lay the tank down after pouring the water out and lift the bottom and shake it to make the resin all lay on the bottom of the side and put a finger in the end of the DT and put the DT in the tank without 'plowing' resin (hold it up against and slide it along the top side of the tank) until the point of the DT gets into the dimple in the bottom of the tank.
    Jul 2012
    Illinois
    I actually did tell them the size (as well as who made the tank and the model number). I assumed they'd size all that for me or at least recommend what I needed. The salt setting was 18 (not the 15 that is what's usually set by default), the BLFC is .5 and no DLFC. They sold me the resin which was installed as well.
    Did I lose resin? Do I need to replace it?
    Thanks, Gary.
    Nov 2010
    Maine
    The only way you will know if and how much resin you lost is to do as Gary said.
    Jul 2012
    Illinois
    My tank has a cover on it so I pulled it apart. The resin (there's no gravel) is about 16 1/4" below the bottom edge of the dome. Is that a problem or should I get more and "top it off" so to speak?
    Sorry, I thought you didn't tell them the size of the tank.
    They forgot to add the DLFC. Make sure the right injector is in the valve.
    You would have to buy at least a 1/4 cuft of resin to 'top it off' if you lost any resin. Ask them what freeboard you should have and go from there. Do not add more than needed.
  1. What size Fleck 5600
    By tj33 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-12-2012, 07:42 AM
  2. Fleck 5600 help
    By croghanite in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-28-2011, 10:46 AM
  3. Fleck 5600 Econominder
    By brew24 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 05-26-2011, 09:14 PM
  4. Fleck 5600
    By CD King in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-14-2009, 07:47 PM
  5. Fleck 5600
    By jjamison in forum Plumbing Forum Discussion & Blog
    Last Post: 11-08-2007, 04:53 PM
