Results 1 to 6 of 6
Thread: should new caulk peel off easily??
    DIY Junior Member dl21's Avatar
    Jul 2012
    seattle
    Default should new caulk peel off easily??
    Hi,
    I asked my first question on on this forum july 5th about my new shower caulking job (see July 5th, "will caulk cure?").I thought maybe I would be OK, but the issue now is that I am able to easily just peel off the new caulk, (there is grout under it).
    Should I be able to peel it off like that? I still have not used the shower, and am wondering if maybe the surface was not cleaned before the contractor used the latasil, I believe, caulk. I understand using alcohol is a good way to clean the surface after the old caulk is removed. I know the contractor removed the old caulk, but I did not see him use any alcohol or anything to clean after getting rid of old caulking.
    Do I need to remove recently applied caulk, prep surface with alcohol and re caulk? Thanks so much!!
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by dl21 View Post
    Hi,
    Is the tile sealed? Was it sealed earlier?
    Are you using Silicone or LAtex Chaulk?
    JW
    Jul 2012
    seattle
    Quote Originally Posted by johnfrwhipple View Post
    JW
    Thanks for your response. It was not sealed. The previous caulk was latex.
    Jul 2012
    seattle
    and the current caulk is silicone. (Latasil)
    Plumber jimbo's Avatar
    No it should not peel off. Getting a bad tube of caulk is a lot more common than you would think. If the caulk is exposed to >100 , or freezing, during transport or storage, it may very well fail. Does it feel like it cured, but is just no sticking?
    Jul 2012
    seattle
    yes. it feels and looks cured, but I can easily, very easily pull it right off. (There was a peice that was sticking up and I pulled it just to see what would happen) Thanks. Sounds like I should recaulk?
  1. Remodel with popcorn and orange peel
    By jperko in forum Remodel Forum & Blog
    Last Post: 06-06-2010, 02:58 PM
  2. 2 wells - How do you switch power easily?
    By boerdoc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-22-2009, 07:21 PM
  3. room center marks for peel and stick tile
    By freebird77 in forum Remodel Forum & Blog
    Last Post: 04-29-2009, 10:01 AM
  4. Silicone caulk vs. latex caulk
    By midge in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-13-2008, 06:28 PM
  5. peel 4" pvc from inside of hub
    By tp85 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-30-2005, 11:08 AM
