Thread: how tight/loose to hang copper pipe?
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    Default how tight/loose to hang copper pipe?
    One of the first projects in the new old house that I am buying is to replace 91 year-old galvanized pipes with copper. I am not sure wat type of hanger to use to minimize noise...whether from water hammer, water flow, or thermal expansion/congtraction. Also how tight do I make the pipe in the hanger?
    Thx
    Hnagers will NOT prevent water hammer noise, but if too tight and the wrong kind CAN cause thermal expansion/contraction sounds. There are many different types of hangers which "snap" over or around the tubing and are then nailed/screwed to the structure.
    Aug 2005
    Columbus, OH
    It won't prevent it, but if too lose it will exasperate the water hammer, no?
    Is there a particular kind of hanger that you recommend or a kind to stay away from?
    I have noticed that in my bathroom here that the water noise, when running, seems to be transfered to the wall where it is amplified. I hear ticking noises too when the pipes are cooling after a shower. And, the ticking noise from the water meter in the basement seems to be reverberated off the family room floor. Those types of things I want to prevent.
    Thx,
    Jason
  1. Existing PVC pipe a bit oval, too tight for new fitting... what to do?
    By vivona in forum Irrigation / Sprinkler Forum
    Last Post: 10-24-2010, 07:06 PM
  2. Cracked PVC pipe tight against pool wall
    By mikemny in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-11-2007, 08:07 AM
  3. pipe through stud: Snug or loose?
    By ToolsRMe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-13-2006, 08:25 AM
  4. How to tighten loose shower pipe??
    By haasek in forum Shower & bathtub Forum & Blog
    Last Post: 01-04-2006, 07:40 AM
  5. How tight - copper to brass threaded fittings
    By tfratzel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-09-2005, 08:57 AM
