Results 1 to 5 of 5
Thread: make bladder a holding tank?
    DIY Junior Member jeeper1's Avatar
    Jul 2012
    Spring Branch ,Tx.
    Default make bladder a holding tank?
    so Im new here and as my first thread I have a good question....so far i have a 380 ft submersible well with a pressure tank. The pump is having issues building pressure. What i have done is lowered the shut- off pressure to about 20 and taken most of the air out of tank. Then I added a shallow well pump and bladder tank that supplies house, set this at 55 lbs. My question , is this a proper way of using pressure tank as a holding tank? I guess I really need to change the down-hole pump and put in a surface tank for the long haul.....
    Thanks for any replies.....
    Feb 2011
    NW Ontario, Canada
    The answer is no. A tank that is designed only for pressure should never be subjected to a potential vacuum.
    Moderator valveman's Avatar
    Mar 2006
    Quote Originally Posted by jeeper1 View Post
    That is a pretty good Bandaid on a bad situation. The problem comes when the booster pump is putting out more than the well pump can give it. You shouldn't need the booster if the well pump was working as it should. Your well pump is not puting out what it should or you have a hle in the well pipe. If you don't fix the real problem, it won't be long until you don't have any water to boost.
    Jul 2012
    Spring Branch ,Tx.
    actually seems to be working preety good for the time being......
    Jan 2008
    It's a bit like using duct tape to stop the oil leak on your truck.
    It might work for a little while, but you will be much better off just fixing it the right way.
  1. sewer holding tank
    By Mike and Cindy Ford in forum Plumbing Forum Discussion & Blog
    Last Post: 09-29-2011, 04:18 AM
  2. Holding Tank Setup
    By milkman1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-21-2009, 07:19 PM
  3. Sizing a well holding tank
    By Michigan Jeff in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-26-2008, 01:47 PM
  4. Holding Tank Concern
    By gmacpro in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-19-2007, 08:50 AM
  5. how can I get the holding tank to work with the well?
    By lories in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-13-2006, 08:32 AM
