Results 1 to 11 of 11
Thread: Is my 240v line working?
    DIY Junior Member
    Jul 2012
    Columbus, GA
    Default Is my 240v line working?
    Below is a picture of my main breaker box on the side of my house. The double breaker there goes to my pool breaker box. My multimeter reads 240v when I check the red and black wires in the picture (called main breaker box).
    In main breaker box:
    Black to red is240v
    Black to ground is 120v
    Red to ground is 120v
    However when I check the red and black wires into the pool breaker box, I am only getting a reading of 120v. Shouldn't I get a reading of 240v just like the main breaker box? Reason I am asking is that my 240v pool pump and polaris pump are not working any more after an electrical storm last night . . . I have already replaced the pool pump motor with a new one . .
    In pool breaker box:
    Black to Red is 120v
    Black to white is 0v
    Red to White is 120v
    Black to ground is 0v
    White to ground is 0v
    Thanks for any help you can give me!
    There is some kind of problem. Black to red should be 240.. You are good at the box and not out at the load.
    There are too many questions here....you need an electrician. We don't know why there is a white lead out there. Pure 240 loads are 2 hots and the ground, so you have some 120 going on. Don't get hurt...get help!
    DIY Junior Member
    Jul 2012
    Columbus, GA
    Thanks for the quick response. (And I don't know why my pictures did not post. Probably file size is too large.)
    I will take your advice and call an electrician. I am clearly out of my comfort zone here.
    DIY Junior Member
    Jul 2012
    Columbus, GA
    Mystery solved. Electrician diagnosed the problem: The black lead has apparently been cut between the main breaker box and the pool breaker box. Have rewired with new 10/3 UF wire and all is working . Now just need to bury the wire.
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by Newbie2012 View Post
    Bury it deep.
    Dec 2009
    northfork, california
    As above - but most certainly in CONDUIT. Or someone will get hurt or you'll do it again.
    Jan 2012
    Los Angeles, CA USA
    People want to save the cost and trouble.
    Some yellow caution tape is a very good idea.
    Dec 2009
    Yellow caution tape for your 8 year old with a hammer and stake, or shovel? Or you with a shovel? Not to mention the same gopher that got the first cable will love the second. Or maybe LA doesnt have gophers OR pumps. Conduit is about 12 cents a foot.
    Jan 2012
    Los Angeles, CA USA
    Don't get me wrong. I would insist on conduit.
    The burial stuff needs to go down what? 2'? I can't even remember, because I won't use it.
    If you trench to 2' and fill to 1' and then lay in the caution tape, you have a MARGINALLY safer installation. Nothing compared to conduit.
    Not sure that the OP said a gopher got it, but that is as likely as anything, I suppose.
    And no, not lots of gophers. I got bloody fruit rats which the cat insists on killing and then eating about 3/4 of the way and leaving me to eat the rest, if I want. She is so generous.
    And squirrels. Of course. The bastards just rat-copulated my apricots this year.
    Possums. Again, the possum kits get eaten.
    Raccoons. Take a pretty mean cat to go after a raccoon. Had one die in the back corner of the yard and rot for a few days. Thank the lord that the city will collect those.
    And last summer a skunk walked in the house. How do you frighten a skunk out of your house? YOU DO NOT!
    Been getting whiffs of skunk many nights of late. The cat needs to learn that no means no.
    Dec 2009
    Under the caution tape lay some junk wood or 2x4 stickers. last a long time buried 2' deep.
    Jan 2012
    Los Angeles, CA USA
    Even better. Pour a little concrete. On top of your plastic conduit. Nearly bullet proof.
  1. 240V across mains but not across bus bars?
    By ColdShower in forum Electrical Forum discussion & Blog
    Last Post: 02-19-2012, 03:06 PM
  2. How much for a new 240v outlet? (800??)
    By Briandl in forum Electrical Forum discussion & Blog
    Last Post: 05-21-2011, 01:44 PM
  3. Replies: 1
    Last Post: 08-19-2010, 11:35 PM
  4. Main Water line not working
    By LauraMM in forum Plumbing Forum Discussion & Blog
    Last Post: 12-18-2008, 06:56 PM
  5. 240v single pole?
    By hids2000 in forum Electrical Forum discussion & Blog
    Last Post: 08-11-2007, 07:37 AM
