Results 1 to 14 of 14
Thread: Tub spout removal?
Hybrid View
    DIY Junior Member paperprofit's Avatar
    Apr 2005
    Delaware
    Default Tub spout removal?
    Need to remove my tub spout (for new surround). Tried turning it counterclockwise to unthread it but it didn't budge. Do I need to use a strap wrench, perhaps, or could there be a locking screw hidden that needs to be loosened first? Faucet assembly is Delta or Moen. Thanks, guys!
    There are essentially two ways to hold the tub spout: threaded, or push on. If it is push on, then there will be a setscrew accessable from somewhere on the bottom. It might be recessed, and seeing it can be a pain. A mirror might help along with a bright light.
    Keep in mind that if they used silicon to seal it to the surround, that acts like a VERY strong glue, and you have to break that seal first regardless of how it is attached.
    Delta will usually be screw on, but Moen is usually set screw, but they could be either one. WIthout being there we cannot tell you which you have.
    Apr 2005
    Delaware
    Thanks again, guys! I found 'Moen' stamped on the valve escutcheon and I was able to force it the spout to turn with a strap wrench (since I saw no set screw). BUT, the spout STILL won't come off. (I'm turning it counter-clockwise as I stand inside the tub). Did I miss a set screw somewhere? Thank you so much for any suggestions! Anxiously waiting! (I'll post a photo I took, if you think it would be helpful, as soon as I find the cable for my Blackberry.)
    A set screw would be visible under the spout in a small slot. It uses an allen wrench.
    Apr 2005
    Delaware
    Terry, No luck. There is no set screw. I'm quite certain. I checked throughly. Should I just yank hard?n Thanks!
  1. Tub Spout Removal
    By andoo in forum Shower & bathtub Forum & Blog
    Last Post: 04-06-2011, 05:30 AM
  2. Tub drain removal for tub removal
    By FJK in forum Plumbing Forum Discussion & Blog
    Last Post: 01-10-2010, 03:21 PM
  3. Tub Spout Removal
    By Leemonster in forum Shower & bathtub Forum & Blog
    Last Post: 05-02-2008, 05:57 PM
  4. Gerber Tub Spout Removal
    By SavercoolD in forum Shower & bathtub Forum & Blog
    Last Post: 10-24-2005, 10:37 AM
  5. Shower Spout/Diverter Removal
    By Golftall in forum Shower & bathtub Forum & Blog
    Last Post: 06-01-2005, 06:25 AM
