Results 1 to 7 of 7
Thread: Can I tie a washing machine into a bathtub drain line?
    DIY Junior Member jonathaninsc's Avatar
    Jul 2012
    South Carolina
    Question Can I tie a washing machine into a bathtub drain line?
    Is there any reason I would not want to tie a new washing machine into a bathtub drain as long as I give the washing machine its own P trap? One plumber I spoke with was concerned the force of the washing machine "would suck the water right out of the trap" of the bathtub. Does that sound right? The washing machine is a high efficiency model and uses very little water. Also, can I use an AAV to vent the washing machine?
    EACH trap needs its own individual vent. A tub drain might be as small as 1.5". A washing machine drain needs to be at least 2". So, probably not, but it would depend on how things are layed out. If each trap is properly vented, then, no, neither should siphon the other. Some places do not allow an AAV, so even if it might work, it would not be to code. It is always better to do an atmospheric vent if possible. Keep in mind that an AAV can only let air in, and depending on where it is, sometimes air needs to come out as well.
    Yakima WA
    I believe the question of AAV on a washer was addressed recently, and if I remember correctly, the can not be used for the reason Jim noted on an AAV only letting air in. Also as noted, washers now require a 2" drain.
    It's more about the venting.
    Your plumber has mentioned that water from the washer discharge will suck the tub trap dry.
    If you were to go downline of the tub line, after it has been vented, and then branch off the 2" waste line, with an above floor trap and vent for the washer, that would work. The two should work independent of each other.
    A washer discharges with a pump. Some locations require a 3" line after the 2" trap and trap arm.
    Jul 2009
    North Vancouver, BC
    Terry is there not also a certain fall that needs to be realized? I think its something like 36".
    JW
    There's a minimum height of the standpipe, but that is separate from any normal slope once it hits the drain. That height varies based on your local codes.
    Jul 2009
    North Vancouver, BC
    It's the vertical drop of the stand pipe. I think it needs 36" of drop before hitting the PTrap. What is the requirement in New England?
    JW
  1. how about this washing machine drain line?
    By diyfun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-26-2011, 07:19 AM
  2. Add a drain line for a kitchen sink to an existing drain line for a washing machine?
    By Loflow in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-25-2011, 05:49 AM
  3. Help Please! How can I install a washing machine drain line?
    By rxs227 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-14-2010, 10:47 AM
  4. Re rout drain line to washing machine
    By db8171cakes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-10-2007, 01:15 PM
  5. Adding washing machine to drain line
    By Mark Jones in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-13-2004, 03:29 PM
