Results 1 to 3 of 3
Thread: will caulk job cure?
    DIY Junior Member dl21's Avatar
    Jul 2012
    seattle
    Default will caulk job cure?
    Hi,
    I just had my new shower (no tub) caulked. My contractor used silicone caulk (latasil), and I know that the shower was completely dry before caulking. The problem is that the shower was accidentally used for a 10 minute shower 4 hours after my contractor had finished, and then, once again for another 10 minutes, the next day. After the second shower, I figured out my son had used it (he vopletely forgot I had told him NOT to use the shower for 2 days I dried the seams (that had been caulked) with a towel and it has not been used since. It has been 2 days since it was used last.
    When I press on the caulk, it feels somewhat soft, but does not feel sticky or tacky. My question is, do you think it will cure OK, and is there a way I can test the caulking to see if it is Ok, or what should I look for?
    Thanks!!
    Some caulks can take up to a week to cure completely, but are generally skinned over in a short time. If the bond was not broken to the tile, and especially if you have porcelain tile that doesn't absorb much of any moisture, you may be okay. You might want to call the manufacturer's help line and ask them.
    Jul 2012
    seattle
    Thanks so much Jim. It is porcelain! Yipee. I need all the help I can get Great idea to call the manufacturer. Thank You!
  1. One Minute Cure
    By DonL in forum Health and Wellness Forum
    Last Post: 01-09-2012, 01:45 PM
  2. abs cure time
    By Rocknroj in forum Plumbing Forum Discussion & Blog
    Last Post: 03-15-2009, 08:47 AM
  3. Silicone caulk vs. latex caulk
    By midge in forum Plumbing Forum Discussion & Blog
    Last Post: 07-13-2008, 06:28 PM
  4. Cement cure time?
    By djqfr in forum Plumbing Forum Discussion & Blog
    Last Post: 06-10-2007, 02:38 PM
  5. Cure time for concrete patch
    By Mike50 in forum Remodel Forum & Blog
    Last Post: 09-17-2006, 10:16 AM
