Fleck Pentair 5800LXT first review
ditttohead
Water systems designer, R&D
Ontario California
Sorry about the bad picture, I installed this on the 4th of July and only had my camera phone with me and it was at night in bad lighting. This valve was installed on a 13" x 54" tank, 2.5 Cu. Ft. System with a 304 brushed stainless jacket, 3/4" flex install, replacing an existing ProFlo 5000SE
I have been bench testing the new Fleck 5800LXT valve for a few weeks and my first impression was that this valve could be a viable alternative to the SXT electronics. The valve itself is classic Fleck with the addition of a high speed DC drive, and a one piece stacked seal and spacer kit assembly. The valve is able to cycle from service to backwash or any other cycle in less than a second. This is a great feature compared to the slower moving control valves. It even makes the WS1 controls seem very slow. For the field technicians, this will save them a few seconds. While this is a unique feature, it does not make the slower drive valves worse in any way. The slower drive systems simply take longer to get between cycles. This may take an extra minute or two during a service call or during a syncronizing cycle or testing.
The valve is loosely based on the ProFlo design and shares the injection system, the drain, and the valve body appears very similar. The ProFlo valve is one of the great Fleck valves for its simple design, high flow, high backwash, and overall durability. Sharing the design was a wise choice. The valve also shares the same meter, bypass, and plumbing connectors that any Fleck installer is familiar with. It uses a 1.05" manifold and I replaced a ProFlo 5000 with this valve. It is a direct replacement, no plumbing was needed.
The LXT programming is a 4 button design and fairly intuitive once you go through the programming a few times. It appears to be based on the Autotrol programming and has a similar "feel". Programming it is a breeze as long as you understand a few limits. The programming is set to the injector size and BLFC size. So programming it for a 2.5 Cu. Ft. systems means it must have the correct injector #0 and a .25 GPM BLFC button. If you do not install the correct BLFC or injector, the system will not work correctly. The programming is set internally based on system size and is not adjustable unlike the SXT. This is fine for the vast majority of applications. I would recommend the SXT for installations where better programability is needed. Systems with Iron, sediment in the water, etc may need the more adjustable programming of the SXT.
Some minor notes, the salt setting is adjustable from 3-18 pounds per cubic foot. When you set the salt pounds, this is a "per Cubic Foot" adjustment, not total salt pounds. The programming will autmatically set the refill time, system capacity, reserves, etc.
The reserve programming is a "Day of the week reserve" and it calculates a reserve for each day based on the past 4 weeks.
Getting out of a programming mode is simple once you do it a couple of times. Simply hold the regeneration button for a few seconds. You must do this to save programming changes.
The LXT also includes the most important diagnostic features and are very easy to access.
Days since last regeneration
Current flow rate
Current days water usage
Total water usage since last regeneration
average daily water usage for days 1-7, very useful if you need to see when and if a water spike occurs regularly.
The very early prototype versions of the valve I was testing had some minor programming issues, this actual production version has taken care of all of those issues. I have not found any programming errors yet. The inability to adjust the cycles makes this more like the Clack valve than the Fleck SXT series programming which allow the user to have total control over the programming. This is good for most since it lessens the potential that people are going to be playing with the system to much. It also makes it much easier for the homeowner to adjust the salt settings for extreme efficiency and to let the homeowner ultimately decide if they are happy with the slightly lower water quality that can occur when ultra low salting is used. It is very easy to adjust the system from 3 pounds of salt per cu. ft. all the way up to 18 pounds per cu. ft., the valve self corrects the rest of the programming including the regeneration cycle times, capacities, reserves, etc.
From a technical standpoint, I prefer the XTR, NXT, SXT programming for their ultimate adjustability, but I also find myself impressed with the LXT. This valve can make those critical and sometimes difficult salt efficiency adjustmants a breeze for many dealers and especially the homeowner.
I highly recommend this valve for most customers on municipal supplies. The LXT may not be the best choice for well systems due to the lack of adjustability where extreme variances in water quality can be overcome with a highly programmable valve. If the well produces consistent quality water, the LXT should be just fine.
The LXT ad SXT boards are easily changed in the field in under 30 seconds, so I see no reason to not try the LXT for the majority of installations. If more programming is required, simply switch it to the SXT later.
The original problems of fast cycling water hammer on the 5800 prototypes has been eliminated with better homing programming and what appears to be a soft finish. The valve quickly goes between positions, then at the last moment, it slows slightly to eliminate the hammer. The original complaint of the difficulty in reading the board from any angle other than straight on remains.
With extremely high flow rates, higher backwash rates, and a very high quality build, this valve can replace much of the Fleck product line. It should eliminate the need for the 2510 valve (one of my all time favorite Fleck valves), the ProFlo, and the 5600SXT can all be replaced with this valve. Once the XTR programming is available, this valve could also replace the 6700XTR as well. The 7000 series controller will still be a very popular valve due to its larger size, higher flow rates, and for application over 1". I definetly see this valve competing with the high end 1" valves by any other manufacturer, and likely bettering them.
My only real complaint is the continued use of the brass BLFC that has been common for decades on fleck Controls that uses a traditional compression fitting on the brine line instead of the hand tightening design on the 7000 with a quick disconnect. This is a very minor issue that does not detract from the overall build quality or functionality of this valve.
msilver
Could you give me some guidance on how to get started with this system? I had it installed and have no idea how to run the thing now. The manual is over my head. In the "Start up Instructions" it talks about positioning the valve, but doesn't tell you how to do that....the manual stinks for someone like me that needs a bit more hand holding....
I looked at http://www.pentairaqua.com/Files/KnowledgeBase/ItemDownload/en/43359-01-rev-a-my13.pdf
For an instance of your specific question, I found "Position the valve to the brine / slow rinse position." That is in the "START-UP INSTRUCTIONS". I presume your installer already did the start-up items initially. However to do that step, if I understand correctly, you would do these steps from page 5 as printed (page 6 by the PDF reader's count):
Manually Initiating a Regeneration
1. When the system is in service, press the Extra Cycle button
for five seconds on the main screen.
2. The control advances to Regeneration Cycle Step #1
(backwash), and begins programmed time count down.
3. Press the Extra Cycle button once to advance valve to
Regeneration Cycle Step #2 (brine draw and slow rinse).
(more steps continue in manual)
msilver
My installer only hooked the pipes up to the main water line. I hooked up the brine tank to softener per YouTube vid. Installer didn't know the system.
Yes, the manual you attached is similar to the one I have, mine just includes the LXT interface too. In any event, I had already tried to manually Initiate the Regen by holding down the Extra Cycle button for five seconds. It appears to start Cycle #1, and as I hit the Extra Cycle button again it appears to jump to the various stages; however, it's not pulling from the brine tank or refilling it, so i'm not sure it's working. It would be nice if the manual went into more detail....I'm at a loss until I can get someone out that can help me with it, I guess.
When you get that person out, it would be best if that person does a lot of water softener work. That will be time-efficient.
How much water in inches is in your brine tank?
How much salt in inches is in your brine tank?
Gary Slusser
That's all folks!
My experience with the Clack WS-1 ended 4 yrs ago but of the 3 versions, 2 allow setting the length of time of the various regeneration cycle positions. IIRC the first version you couldn't, the 2nd and 3rd, the CS and EE versions you can change the time. With the CS you change a P number and the EE you set the minutes for each cycle. Again, IIRC, in all versions you set the gpg of compensated hardness and total lbs of salt in lbs.
After reading the above.... From my point of view, developed through selling to DIYers from 1992 to 2010 (from Puerto Rico, across the US and Canada to Alaska), there is no better choice than a CS version of a Clack WS-1 for anyone wanting to do their own repair etc. of their softener.
ditttohead
Ontario California
The LXT version is one of the simplest and easiest valves to work with. The programming has been simplified compared to most other valves. I sent you a PM, call me anytime and I will walk you through it.
Gary Slusser
That's all folks!
I thought I read something above about programing the LXT that wasn't all that good so, I scrolled up to the top and where you said:
ditttohead
Ontario California
The programming of the LXT is the simplest if you know to lock any changes by holding the regen button for 2 seconds. It is not programmable for specialized applications, similar to the WS1. For 95% of applications this is fine. The SXT and XTR2 are more programmable and should be used when unusual water conditions occur.
I have been wanting to make a programming cheat sheet for the LXT, but it is so simple, the cheat sheet is actually more difficult to make than the SXT or XTR versions.
Gary Slusser
That's all folks!
If if if if .... and if the person doesn't know to push in and hold some button in for however long, there is no way for an owner to change cycle length times from what you have said.
Also, you seem to not be very familiar with the Clack valves. Only the first version has cycle position times that can not be changed from default (factory, not distributor or dealer) settings.
The CS and EE versions allow changing the length of time for each/all cycle positions. And there is no secret hand shake BS required.
I think the 5800 is a poor choice for anyone wanting to 'work on' their control valve and it will probably languish like the 5000/ProFlo has. Especially since it won't be sold over the internet to DIYers.
DD12
Las vegas
Hello I have this system. After treatment my water is still at 6gpg hardness according to the hach 5b test. One concern I have is how full my brine tank is with water. With my current configurations the brine refill time is 63 mins. Which with a .125 BLFC comes out to 7.875 gallons of water which seems excessive for my application. Do you have any recommendations as to what I should check? Please let me know what more information I can provide. Thank you.
Bannerman
Ontario, Canada
DD12, we will need know the size (total capacity) of your softener and the amount of hardness contained in the water. If your water source is a private well, we will also need to know the amount of iron and manganese if any. It would also be helpful to know the softener's current Capacity setting and the number of people residing in your home to estimate the average water consumption each week.
DD12
Las vegas
Thank you for the response Bannerman.
Size=1.5ft^3 of resin
Hardness= 20(Hach 5B)
Source= Municipal(essentially no iron according to water district)
Capacity: 1.5^3 of resin
I'm assuming you were talking about the resin setting for current capacity setting. As far as people in the home, it's just me. GF is here about half of the time so I would say 1.5 people in the home to estimate. Thanks.
DD12
Las vegas
Thanks dittohead. So essentially that would come out to ~12lbs of salt, correct? My current salt dosage is set to 15, other than this causing more water to be put into the brine tank than your recommended 8 pound setting, how would this affect the hardness of the water? Wouldn't it just affect the regen recurrence? Thanks again for your time.
ditttohead
Ontario California
It will slightly decrease the quality of your water, but to such a small degree that you would never notice. it will cut your salt usage considerably.
