Results 1 to 3 of 3
Thread: Patching concrete in driveway questions
    DIY Senior Member chris fox's Avatar
    May 2007
    near phoenix AZ
    Default Patching concrete in driveway questions
    I need to patch a 2'x5' saw cut hole in my driveway which had to be done to repair a water main burst.
    My plan is to first add gravel then top with sand and water to get my depth back to about 4-5".
    Then drill holes in sides of concrete about 1/4 way up from bottom for #4 rebar stakes and epoxy them in.
    Then lay in re bar in lattis configuration and tie to keep all suspended and together. Then pour concrete and float.
    Am I on the right track to prevent cracking due to driving over?
    Thanks in advance!
    DIY Junior Member tropics surfer's Avatar
    Jan 2012
    Puerto Rico
    Yes, you are. If possible, the sides of the hole you are repairing should be angled outward at the bottom, so the new patch will not have wiggle room. You could use a chipping hammer to cut the angle. Also, consider using a bonding agent on the edges of the concrete (around the area already cut). We use a product called Bull Bond- it's water based but it works- look for it in a quart size, what you don't use will keep quite a while for future use. And if you have to add a little topping of cement to level it to the exisitng driveway surface, coat again with bonding agent first.
    Not sure what you mean about topping with sand and water, though. Gravel and sand packed down with a tamping tool before you mix the cement should work fine.
    I would add some screened sand to your cement when mixing; I think it'll make it more durable.
    Besides the rebars, I would "distress" the cut edges so the concrete has recesses to key into.
  1. Patching concrete floor after rough plumbing
    By ktambascio in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-16-2009, 07:06 PM
  2. Resurfacing concrete driveway
    By Dirtballer in forum Remodel Forum & Blog
    Last Post: 05-29-2009, 02:44 PM
  3. Questions on pouring concrete around new rough-in
    By Vinniejt76 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-29-2008, 07:02 AM
  4. Hole patching.
    By sinkerator in forum Remodel Forum & Blog
    Last Post: 02-02-2008, 12:30 PM
  5. concrete driveway over utilitys
    By toolaholic in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-15-2005, 05:40 AM
