Results 1 to 4 of 4
Thread: Correct placement of Flexcon Flow-Thru FT-18 pressure tank help.
    DIY Junior Member Scott Stemen's Avatar
    Jul 2012
    Arizona
    Default Correct placement of Flexcon Flow-Thru FT-18 pressure tank help.
    Describe Problem_
    Mounted inside my 1750 Gallon Water Cistern is the Grundfos SQE pump and a small 4 gallon pressure tank (Flexcon FT18). I have been told by well & pump guy the pressure tank should not be mounted in the cistern and horizontal isn't good either. I would like to move it to a different location but can't find installation instructions on the web.
    Currently the 4 gallon stainless steel pressure tank sites inside my main water cistern attached in a horizontal position about 4 feet directly above the SQE pump.
    Have been told the purpose of this tank is to provide some (electrical term) capacitance for the pump as it turns on and off while providing water pressure to the house. Flush a toilet get a drink of water the pump would just click on then suddenly off and that i have been told is bad for the pump. So the purpose is to be a bit of a spring so the pump doesn't surge. (this is what I have been told its reason for existence. )
    Question #1 Must this 4 gallon pressure tank be as close to the pump or can it be anyplace in my entire water system as long as no check valve is between the pump and the FT18?
    My thinking is that if the tank was moved from inside the cistern and placed in the garage but on the same cold water line it would perform the same action. There are no check valves between the pump and my water heater in the garage. Just the house with all it's water pipes and sinks and toilets. However if placed in the garage then the pressure tank would be basically the last thing on the line before the water heater.
    Question #2, If I cannot or should not mount it in the garage, (other end of the house) can I mount it about 15 or 20 feet from the pump and tank. I have a good clean location and it would work well. It would be the first thing on the line from the pump before the house. It would be moved from inside the water tank and be outside in the elements, but I would put a small housing over it to protect it.
    Two pictures are attached since pictures were requested.
    Image called FT-18-post.jpg is the image of how the tank is mounted now.
    Image called FT-18-Place-POST.jpg is the distance from the tank to a window where I would place this thing if my Garage idea isn't good.
    Any help would be great Don't hesitate to ask me computer questions.
    Water pressure / tank
    Flexcon Flow-Thru
    Model FT18
    Manufactur date shows 09.03
    Installation date is May of 2007
    Type of pump?
    Submersible__YES______
    Two wire (no control)__NO______
    Three wire (control box)__YES____
    Wire Size_____? 10 gauge____ Wire Length__? 10 feet______
    Pump is inside water holding tank.
    Size of Pump?
    Motor Horsepower?_____? think 1/2 horse_____
    Pump Model #__Grundfox SQE__
    Date Pump Installed__2007___
    Pumping from?
    Cistern tank___YES____
    Depth to water_4 feet___
    Pump Setting__? ____
    Pipe Size__1 and 1/4 __"
    Drop Pipe Material
    PVC_YES_______
    Pressure Tank?
    Bladder or diaphragm tank (one pipe to tank)___4 1/2 gallon bladder _______
    Size or model of tank_Flexcon Flow-Thru FT-18 _
    Air charge in top of tank, with pump off and water drained____40 +/- 5 pounds last time checked_PSI
    Pressure Switch Setting?
    On 30, off 50 __? Unsure______
    Pump Control Method?
    Cycle Stop Valve model #__? controler is CU 301 _______
    Variable speed control #___?_______
    Pump Start Relay (sprinkler timer, no tank)__?________
    Manually turned on and off__NO Auto__________
    Pump Protection
    Cycle Sensor_________
    Pumptec_____________
    Low pressure cutoff switch (lever on side)__________
    Other__Water level in tank switch _____
    Filters or Softeners___Filter and softener___________
    Before or after pressure tank_AFTER both pump and tank__
    Type of filter____1 inch line into compressed carbon single block filter from Home Depot____
    Bypass available__Not yet can be installed if recomended______
    Water Used For?
    House Use__Yes_____ Number of baths__3__ Number of People__2___
    High Flow Showers__? no clue ___gpm?
    Plus/Or
    Irrigation with timers________NOPE
    Irrigation with hoses________NOPE
    Heat Pump_~NOT ~ _gpm?
    Problems Experienced
    No Water__Nope
    Water only part time__Nope_
    Water at all times but weak__Nope
    Air in water___Nope
    Pressure surging___Nope
    Water Hammer (noise)___Nope
    Too Much pressure___Nope
    Pump makes clicking or buzzing sounds__Sounds normal______
    Pressure gauge reading__Set to 80__psi
    Do you have, and know how to use
    an Ampmeter and Voltmeter___Yes, I also have the Grundfos R100 controller that will control the CU 301 pump control panel. Great at soldering copper pipe and electronics. SUX at PVC piping.
Size:  65.7 KBName:  FT-18-Place-POST.jpg
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    Those pumps can be installed in wells hundreds of feet deep, which makes them hundreds of feet from the tank. I think the important thing is to keep the pressure tank and pressure transducer together.
    Jul 2012
    Arizona
    Forgive my stupidity. What is a transducer? you mean the pressure sensor that is about 12 inches from the tank.
    Mar 2006
    Lubbock, Texas
    Yes and the transducer “pressure sensor” needs to stay within 12” of the tank. The whole idea of the flow through tank is to keep the water in the tank from getting old, stale, and contaminated. That is because with those variable speed type controllers, there is no pressure bandwidth to allow the use of any water from the tank. The water that is in the tank stays in the tank forever. The water in the tank would get nasty, and the next time the power goes off, the tanks air charge would shove this nasty water into the house.
    So the “flow through” nozzle at the entrance to the tank circulates water inside the tank as water flows past it in the mainline. This hopefully keeps the water in the tank from turning green. Since the tank cannot be used to store any water, the pump must come on every time you crack a faucet open, even for just a small glass of water.
    This makes the main purpose of the pressure tank to cushion the “pressure sensor”. The pressure tank and “pressure sensor” need to stay close together so the pressure tank can cushion the sensor from the pulses in pressure that happen when the pump starts, stops, changes speed, or when you open or close a faucet.
    It is good that you are moving the tank and “sensor” out of the cistern tank. Because the place where the sensor is attached, is the same place you will need to install a regular 40/60 pressure switch when the CU301 controller quits working. Yours has already lasted longer than normal, probably because you don’t have any outside watering, and the pump apparently doesn’t get a lot of use. The age of that CU301 controller means that it is probably about the fourth of about six versions produced. Which means it will revert to cycling the pump on and off like a regular pressure switch, and will do this about 500 times before it shuts down and alerts you that the CU301 and motor have lost communication. This is usually when I get a call and show people how to replace the CU301 and “sensor” with a regular pressure switch, and where to add a Cycle Stop Valve to produce the constant pressure and keep the pump from cycling. Sometimes they don’t start looking for an answer until they have replaced the CU301 three or four times, and are very angry by the time they call me.
  1. Replies: 2
    Last Post: 08-19-2010, 11:56 PM
  2. Replies: 1
    Last Post: 05-14-2008, 10:13 AM
  3. attic tank to increase pressure/flow
    By Erico63 in forum Solar and Geothermal Water Heating Forum
    Last Post: 03-20-2008, 07:13 AM
  4. attic tank to increase pressure/flow
    By Erico63 in forum Pumps and Tanks Well Forum & Blog
  5. Pressure tank placement
    By almostdone in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-30-2005, 06:44 AM
