Results 1 to 2 of 2
Thread: Wiring a jet pump in conjuction with a storage tank
    DIY Junior Member Terrasmooth's Avatar
    Jul 2012
    Northern Arizona
    Default Wiring a jet pump in conjuction with a storage tank
    Hello,
    I have a 3/4 hp jet pump that I want to use to pump water from my storage tank to my pressure tank.
    I have the high and low floats for the storage tank, I need a wiring diagram to wire this setup. Do I need a control box for the jet pump?
    www.terrasmooth.com
    The switch for the lower float has to open when the float drops and the upper one has to open with the float rises to fill the tank. You can wire them in series to control the pump's operation, Once it is full you only need to wire the lower one to stop the pump when the storage tank runs out of water, but you also need a controller to tell the pump when the main tank needs water.
  1. Quiet pump for pumping water from a concrete storage tank in the basement
    By luc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-29-2009, 10:40 AM
  2. Storage tank setup
    By jdieter in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-26-2009, 08:12 AM
  3. Upgrading storage tank
    By SilverFox52 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-20-2009, 03:34 PM
  4. Storage Tank for well
    By dtbmous in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-22-2007, 10:16 PM
  5. Replies: 0
    Last Post: 12-17-2006, 05:28 PM
