Results 1 to 6 of 6
Thread: How do I replace a shower with a bigger better shower?
    DIY Junior Member deviddiya's Avatar
    Jun 2012
    India
    Default How do I replace a shower with a bigger better shower?
    At pesent I have a free-standing shower (touching only the back wall). I want to replace with a nicer shower(one that is not free-standing - touching 3 walls). I will not be able to find a shower that is exact size between the present side walls. I will need to extend the two side walls out about 3 to 4 inches to meet the shower walls. What is easiest type of wall to build? Do the shower walls have to be glued to drywall or will plywood work? I am limited on placement of shower due to the drain which is exatly 18 inched from the back wall.
    Jul 2009
    North Vancouver, BC
    I could built you so many different showers with that exact set up. For one you can use the existing drain location and switch out the old drain pan for a new clamping drain and custom shower pan or a linear drain and custom shower. Building a custom shower starts with taking everything out and starting new. New tile prep. New tile. New plumbing. New fixtures and on and on.
    Your toughest task is setting up a budget for this new shower and finding out if you can afford to do the entire shower custom or work with some ready made shower kits. Find the number you are comfortable paying and then work backwards. Make sure you budget only 70% of your maximum so you have a little in the kitty for pop ups.
    Loads of my clients hire me to build the shower pan, curb, install the backer boards and waterproof the shower - then they take it from there. If you can do it all you only need to budget for the materials.
    If you only have one shower then building a new custom shower can be a real drag so faster methods and more expensive shower building materials can save you some time.
    JW
    Some surrounds don't need anything on the walls, some can go against drywall, some want cement board. You need to choose your materials, THEN figure out what you need to do to support the wall properly.
    But, if you can find the materials, the way to make a new shower fit in your exact available space would be to do a custom tiled shower. Not sure what materials are available in your country, but local customs may not actually produce a good shower...there is a real science to building a good, reliable, long-lasting, trouble-free custom shower. If you can get the materials, this would be my first choice.
    DIY Junior Member decrem's Avatar
    Jun 2012
    Orlando FL
Size:  13.3 KBName:  handymaninOrlando2.jpg
Size:  15.7 KBI have been a Handyman in Orlando Fl for over 20 years and Personally I would not use drywall or plywood I would use wonder board or some people call it cement board. Over time drywall tends to deteriorate because of the prolonged exposure to humidity and water. I have seen shower walls done with drywall that literally come crumbling down. Don't use drywall, at least not in the Shower area. as for the walls you can use 2by3 or 2by4 to frame it the way you want it and just tile over the wonder board. Hope this helps
    Robert Merced
    407-300-1274
    Bobby's Handyman Service
    Handyman in Orlando Florida
    BBB and Angie's List Approved !
    DIY Junior Member SteveBath's Avatar
    Jul 2012
    NC
    Nice shower there ... I would be concerned about a free standing shower - but I would like to see a high quality one somewhere.
    Wedi makes some neat freestanding showers if you like the style. Here's one, but they have others.
  1. shower remodel - old shower supply is PVC/replace with CPVC
    By carrotguy in forum Shower & bathtub Forum & Blog
    Last Post: 10-01-2008, 12:36 PM
  2. Replace shower Plumbing Valve assembly shower head 2 knobs
    By scri8e in forum Shower & bathtub Forum & Blog
    Last Post: 12-30-2006, 10:24 AM
  3. Replace tub with shower
    By marnab in forum Shower & bathtub Forum & Blog
    Last Post: 03-31-2006, 08:02 PM
  4. Replace 60 yr old shower?
    By gmilton in forum Shower & bathtub Forum & Blog
    Last Post: 08-24-2005, 09:36 AM
  5. replace tub with shower
    By Ldybug4488 in forum Remodel Forum & Blog
    Last Post: 10-18-2004, 07:10 PM
