Thread: Reliability of cable-driven bath waste?
    DIY Junior Member cheakamus's Avatar
    Feb 2011
    Seattle, WA
    Default Reliability of cable-driven bath waste?
    I was sold a cable-driven bath waste and overflow mechanism with my tub, but I'm hesitating to install it because the cable "gearbox" will not be accessible once it's installed. Should it go wrong, I'm not sure I could retrofit any other type of stopper. I also wonder whether it might have a propensity to leak, since the cable or an axle penetrates the pipe. The manufacturer is Westbrass and the model # is D50P27. Has anyone had any experience with type of mechanism?
    I have had customers break the fittings, but no matter what happens to it, you will NOT be able to repair it unless you can access the area behind and under the tub.
    Feb 2011
    Seattle, WA
    Thanks, HJ. That confirms it then — I'm definitely not going to install this drain and will instead look for a simpler drain with perhaps a toe-tap type stopper that can easily be replaced.
  1. Bath tub waste & overflow drain installation.
    By motonutz123 in forum Shower & bathtub Forum & Blog
    Last Post: 11-13-2010, 07:30 AM
  2. Cable Drain (long cable needed)
    By dick2222 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-11-2009, 07:03 PM
  3. Cable Bath Drain Question
    By CamaroDave in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-06-2009, 12:50 PM
  4. Waste and Overflow -- cable drive or push pull
    By remodelbob in forum Shower & bathtub Forum & Blog
    Last Post: 04-05-2008, 12:58 PM
  5. Kitchen and bath sink to 3" waste line
    By VT David in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-08-2007, 03:53 AM
