Did I waste my time? Pumping from a pond
Masterpumpman
Virginia Beach, VA
www.dci-inc.us
I'm a little late getting into this but as the pond level goes down so will the flow from any shallow well near it. In most areas you're just circulating the water from the pond back to the pond. The only way to obtain 25 gpm from a well in your area is to have a deep well with a submergible pump. Sorry what is, is!
LLigetfa
DIYer, not in the trades
NW Ontario, Canada
First 7.5 ft is sandy loam.
Next 2.0 ft is red silt clay.
Next 5.5 ft is blue-gray silt loam clay.
At 15 ft, glacial till...
If there is an impervious layer of clay between the pond and the aquifer the well is drawing from, it is possible that the two are not one aquifer. That said, 7.5 feet probably is not enough to be impervious and the pond could well be part of the same aquifer.
Even if they are not the same aquifer, when the pond level goes down so too might the well level so the small margin of 8 feet probably would not go far.
ETD66SS
New York
Well, I don’t believe this to be the case in my situation, as I accounted for this when I dug my ponds. The local water conservation specialist from the DEC informed me that the water table in the spring is 18” below grade, and at the driest time of year it is usually at ~68” below grade.
When digging my pond, I clay lined the sandy loam portion of the banks, to prevent my ponds from dropping drastically as the water table fell.
This picture shows the anatomy of my pond banks: http://www.infinity-universe.com/~dev/WhiteDwarf/Projects/Well/Pond/Bank-Profile.jpg
If what you said were true, my ponds would be at the same level as the water table, but they are not. The water table atm is about 6.5 ft from grade, the pond water level is at 3.5 ft from grade.
I lose water for many reasons:
-Evaporation
-Wicking into the banks and evaporating (pond banks are always wet, so I know this to be true)
-Water leeching through the gray silty clay lining into the sandy loam. (This gray clay is not like capping
clay, water can still pas through it slowly)
Now, I know even if I pump water into the ponds, I will still lose it due to all the above reasons, but I believe if I can attain 25 GPM, I will be able to keep the ponds near the springtime water level all year round. If not, it will still be better than letting it drop 2.5-3 ft from May until Sept. As that is about how long it takes in a very dry year like this. The ponds drop about 36” in 120 days. 25 GPM for my pond area gives me the capability to replenish 1” per day of pond level.
The local DEC office tells me shale rock is after the glacial till, between 18-20 ft deep. That is where the water veins start.
This is why I believe 2-3 shallow wells into the shale rock will work for me. Most wells in my neighborhood seem to be between 25-35 ft casings certainly not the 100’s of ft you guys seem to be implying.
This is one thing I have not found good information on. Why do you say a deep well with submersible is required for 25 GPM. Why is it that multiple shallow wells combined can not get me to 25 GPM?
ETD66SS
New York
Well, after all that BS with the crappy Chinese made sand point junk, I had a well dug last Oct. They went down 46 feet with a 19 ft long 6 in casing and got real nice water, he was afraid to go any further because in that area if you go any deeper you hit salt. At this moment in time, the water level in the casing is only 3 ft from grade.
The rig operator told me he got 4 GPM (even though the guy on the phone who quoted me the job said the closest well in that area got 12 GPM, so I could expect to get around at least 10 GPM, then when the rig operator finished the well I asked him why I'm only getting 4 GPM, he said "for this area you're lucky to get 2-3 GPM" gee, thanks for the scam.
I assume if it says 4 GPM on my well cap, I should buy a well pump that is 3 GPM or less?
This is not sufficient for my pond filling needs anyways, so in the end it was a waste of $$.
Also, the well driller told me water from that depth is not from the same aquifer as the water table and the ponds, so I would definitely not just be circulating the water. (but he does sell drilled wells for a living and that company already pulled a fast one on me...)
LLigetfa
NW Ontario, Canada
They went down 46 feet with a 19 ft long 6 in casing...
Can you explain the formation better? How does one have only 19 feet of casing in a 46 foot hole? What is the remaining 27 feet, uncased clay, rock, screen, ???
Maybe the well can be developed to get more GPM.
ETD66SS
New York
He hit the bedrock at 18 ft, went into that 1 ft with the casing, the rest of the depth is just rock. That is how it is done in my area he said.
I live very close to Lake Ontario. I guess after you get through the bedrock, you hit salt deposits. ~45' is as far as they will go in that area. He told me most area wells they only go down ~30 ft, but he had to go down to 46' to get any water at all. At first he was getting 0 GPM, then he shocked it a few times, and ended up with 4 GPM.
How can I test the GPM of this well on my own?
It was drilled during one of the worst droughts on record, I don't know hos good his 4 GPM number really is for a normal season...
LLigetfa
NW Ontario, Canada
You drop in a submersible and tape an air line to the drop pipe. Put a Tee on the top of the air line so that you can have a tire valve and pressure gauge on it. Pump air into it with a small compressor and the pressure you see will tell you how low that water level is. Simple math based on .43 PSI per foot.
Put a ballvalve on the water line to regulate the pump output and adjust it so that there is at least a foot of water above the bottom of the air line. Measure how much water you get in a minute and do the math.
ETD66SS
New York
Ok, makes sense. However, the reason I want to measure it is to know what kind of submersible to buy ;)
I assume I can use some cheapo plastic car battery operated submersible to test with, something I know has more GPM than the well would have?
ETD66SS
New York
Yep, I understand the curve.
But maybe I'm still confused.
My plan was to buy a cheap submersible, use your method for measuring the GPM. If I understood it correctly, I was going to put the pump with open air line in about 4 ft, hit it with a small compressor and the gauge would have a reading. Crack the ball valve and keep opening it until I see the pressure drop. Regulate the ball valve until I see the pressure holding steady. Then measure how much water I get in 1 minute.
However, I don't want to go buy a final submersible until after this test, as they are like $600. I was hoping to get a cheap (~$100) unit form Home Depot or something that can do at least 15 GPM. However, I'm not finding any that will fit in a 6 in casing.
I guess for my test I don't need a submersible, I could use a shallow well pump. Maybe something like this: http://www.northerntool.com/shop/tools/product_200349977_200349977
LLigetfa
NW Ontario, Canada
The air line should be a foot above the intake of the pump so if you set the pump a foot off the bottom, your air line would be around 45 feet.
The GPM output of the well may vary with how low you draw it down so you might be drawing the well down to about 44 feet. That would give you about 44 plus feet of head. The increase in head will reduce the GPM so it will self-regulate somewhat. You add artificial head with the ballvalve. The artificial head also limits the upthrust on the impellers.
If you get a pump that carries the impellers on one bearing rather than float them, you would likely see more of an amp drop as the GPM reduces so a cycle sensor could be used to turn off the pump when the level drops dangerously low.
ETD66SS
New York
Ok, I totally misunderstood your test.
I thougth I was trying to get a GPM where there was no draw down at all, but I guess there is always some.
If I'm going to use this well to supplement my pond level, there will be a sumbmersible in it running 24/7, at whatever GPM the well can replenish. I do not live at this property, so I will not be there to keep an eye on this well pump.
So I guess I have to think about this some more, because the only pumps that will work to do the test are the expensive ones. And I don't want to just go buy a 3 GPM submerssible. I need to maximize the GPM I get out of this well. If I buy a 3 GPM pump and it works fine and can run continuously, I'll always be wondering how much GPM I could have had. 4, 5, 6 or more? etc...
ETD66SS
New York
Hmm, looking at the deep well pumps, it appears I don't have many GPM options. I supposed I'll have to buy a 5 GPM and use a gate valve to simulate head to get the optimum GPM for my well.
