Page 1 of 3 123 LastLast
Results 1 to 15 of 33
Thread: Did I waste my time? Pumping from a pond
    DIY Junior Member ETD66SS's Avatar
    Jun 2012
    NY, USA
    Default Did I waste my time? Pumping from a pond
    I have some ponds located in Western New York. Starting in about May, the water in the ponds starts to drop due to evaporation, and probably some wicking into the banks, and also maybe due to the water table dropping. By about August, the ponds are generally 18-24 in below the normal level at springtime. I wanted to dig a well, to run a pump to keep the ponds topped off and as close to the springtime level as possible. The total surface area of the ponds at springtime is about 1.33 acres. When it is really dry out, I can lose about 1 in of pond level per day. So I decided that I needed a well that could supply (1.33 acres x 1 in deep = 8342611 in^2 * 1 in = 8342611 in^3 = 36,115 gallons/24 hrs = 1,505 gal/hr = 25 GPM)
    I did some reading and noticed that a single shallow well is probably not going to be able to supply that.
    I decided to go ahead and dig the well, and see what kind of flow rate I got.
    The well idea was one from a co-worker. 2 vertical 10 ft lengths of 4 in PVC with a T at the end, and 2 more 10 ft lengths of horizontal 4 in PVC with slots cut in the sides and caps on the ends.
    The idea was to dig a trench 18 ft deep, place the T in the bottom of the trench and cover with stone.
    It sounded like a good well plan, so I tried it.
    It was a disaster. Let me explain the strata. Since I dug the ponds, I know the layers of soil I was going to be dealing with.
    First 7.5 ft is sandy loam.
    Next 2.0 ft is red silt clay.
    Next 5.5 ft is blue-gray silt loam clay.
    At 15 ft, glacial till, which consists of extremely hard & dense red clay that crumbles like concrete, mixed with tailings sized rocks up to 3-4 ft diameter boulders. All these are rounded stones, as this was the bottom of the ancient Great Lakes.
    I've never been able to dig any farther than that, I can usually go to 18 ft with my excavator, but the glacial till is very hard to make any progress through it.
    I knew I'd hit water at about 12 ft.
    The nightmare was basically, the soil strata does not really allow for a trench that deep, the sides kept caving in on me, so I tried to step the trench a bit, even then, the sandy loam just kept giving-way and falling in the trench. I got the PVC T-assembly in the trench the first time, and as soon as I did, boom, a huge section of sandy loam caved in on one of the 10 ft sections of slotted pipe. So I yanked out the assembly, re-dug the trench, and in the process lost that one section of PVC. So I decided I'd cut the one 10 ft length in half, and make shorter handles on the "T". That was easier to manage. Had the trench cleared out, put in the PVC T-assembly, but before I could get any stone on it, about 3-4 ft of each end of the handles got covered in falling sandy loam, I was able to get stone on the rest of it.
    Here are some pictures:
    http://www.infinity-universe.com/~de...Projects/Well/
    So in the end, I ended up with a "T" well casing 17 ft below grade, and a water table 11 ft below grade, so basically 6 ft of water from the bottom of the 4 in PVC T-fitting.
    I bought some 1-1/4 in PVC and fittings, and a foot valve from Home Depot. I then purchased a cheapo Chinese hand pump from TSC. The foot valve has a short screen, the holes are maybe 1/16 in diameter. I only have the foot valve 14 ft deep, when I went to put in the 1-1/4 in PVC, the 4 in PVC was filled with sand about 3 ft high. All that sandy loam that caved in on my T-handles clogged the casing.
    I am able to pump water, but it is just muddy and so full of sand, I think I will destroy that Chinese hand pump soon... I don't really know how to measure GPM, but it seems like I can only hand pump about 2-3 GPM, if I go any faster, I can hear the foot valce sucking air.
    So, after all that crap, should I have just used a driven well point? I know there will be ZERO obstructions from grade down to 15 ft. I also know that the water table is currently at 11 ft, however, in August it is at its lowest, so not sure how much farther it can drop. In the spring, the water table is only about 5 ft below grade.
    So, I need 25 GPM, and knowing the strata I described, what is the best way to go? Multiple driven sandpoints? If I used multiple wellpoints, is there a minimum distance between them? Can I gang them together and run just one pump?
    Thumbs up
    Good news, Have put in 7 wells so far. Please purchase waterhole by Bob Mellin. Inexpensive helpful Lil book. I can't say enough about My $300.00 Borzit boring system. Never used it for a well,Myself But will this summer. I recently doug 2 pits and drilled 30 ft. under a concrete slab. Replaced a rotted cast iron 2" drain line with PVC. Also the owner Jim sent Me a replacement part I broke at no charge. www.borzit.com Get the optional 5" Auger. Have fun. Boston!, P.S. Don't listen to the Nay sayers ! I use My timber wolf offset drill motor to power it.
    Quote Originally Posted by ETD66SS View Post
    Huh, a spammer, ok then...
    I don't understand You! You mentioned putting in a well. I give You a great Book, Great affordable tool, to drill it. Did You Check any of this out?
    Moderator valveman's Avatar
    Mar 2006
    No matter how you drive, drill, or trench the well, a 15’ deep well with a water level at 11’ will be hard to get much water out of. And this is the good time of year. Doesn’t sound like it will be of much use during the dry time of year when you really need it.
    I don’t know if it is possible in your area, but it sounds like you need to go deeper and tap an aquifer to get the water you need. If the pond levels fall in the dry time of year, you can bet the shallow surface water does the same thing.
    I imagine the local Well professionals , Have it figured out. I'm guessing a deep well,drilled
    Jun 2012
    NY, USA
    "dry time" of the year is only 1-2 months away for me, so it's close at hand. Up here, fall is kind of a rainy season, by Oct/Nov, the ponds are usually almost topped off again by runnoff. So May to Aug is when I really need to use this well, which is NOW, this time of year.
    And currently it is a 17' well with 11' water level. I'd expect the water table to drop no more than another foot by Aug/Sept.
    The local water conservationist for NYS is looking into the water table/well data for the area for me, but it takes a long time to hear back from them.
    I did buy a couple wellpoints that I will try to drive through the glacial till, I am unsure what is underneath that layer, the local water conservation dept cannot tell me, as soil maps do not have that information.
    So, you say I would "not get much water out of it" with 17' deep well at 11' water depth. So what is a good well depth if say in mid August, the water table is at 12'? How deep should the well be so that I ensure I "get water out of it"? Is there a rule of thumb for water depth over the wellpoint depth for "enough water"?
    Mar 2006
    6' of water in the well isn't much. And when you start pumping it should be even less. 6' of water will work if you have enough water coming into the well. And I guess you won't know that until you start pumping and see what happens.
    Jun 2012
    NY, USA
    I pumped by hand, and contunied to do so until I could hear the foot valve sucking air. I decreased the rate until I could continually pump for 20-30 minutes without hearing the sucking noise. I then placed a 5 gallon bucket under the pitcher pump and continued at that rate. I got 3 gallons in a 1 minute timeframe.
    If 6 ft of water "isn't much" what is? 10 ft, 20 ft etc...
    Mar 2006
    More is always better, but the water table thickness is what it is, depending on your area. If you are only getting 3 GPM from the point, then you need to tie 9 points together to get 25 GPM. the main point is that the water table will probably get worse when you start pumping on it, and the time of the year also comes into play.
    Jun 2012
    NY, USA
    I talked to a local geotechnical firm that has records of core samples near my property. They tell me the glacial till layer stops between 18-20 ft and then there is shale rock.
    Would the driven wellpoints I try, be better suited in that shale layer as opposed to the silty clay above the glacial till? It sounds like water would flow nicely through shale.
    EDIT: I don't understand how the "pumping from a pond" got added to my thread title, lol... Forum weirdness.
    Dec 2009
    northfork, california
    Dig a 30' deep pond and since the water table is at 11' you should get a nice 19' deep water body with no pump..
    Jun 2012
    NY, USA
    So I decided to try a driven well point this time. I figured since most of the driving would be through sandy loam soil it should go pretty easy.
    I bought the 2" well points form Northern Tool and Equip. http://www.northerntool.com/shop/too...1309_200321309
    Some drive couplings, and it took me forever to find 2" pipe in my area. I finally found a store with 5 10' sections of 2" SCH 40 galvanized pipe. $67 each, which I thought was way expensive...
    I started by using my post hole digger with 12" auger:
    http://www.infinity-universe.com/~de...n/DCP_1091.jpg
    http://www.infinity-universe.com/~de...n/DCP_1092.jpg
    http://www.infinity-universe.com/~de...n/DCP_1093.jpg
    http://www.infinity-universe.com/~de...n/DCP_1094.jpg
    I assembled the first length of pipe onto the well point with a drive coupling and pipe thread compound. Tightening until I no longer could.
    http://www.infinity-universe.com/~de...n/DCP_1095.jpg
    Using my backhoe and a ratchet strap. I leveled the pipe and backed my tractor up to it so I could stand on the roof to start driving the well.
    http://www.infinity-universe.com/~de...n/DCP_1096.jpg
    http://www.infinity-universe.com/~de...n/DCP_1097.jpg
    After driving the wellpoint into the ground only about 3 feet, things started to feel funny. I was tightening the drive cap as I went along to ensure the pipe threads were ok, but the actual connection in the ground felt loose, so I pulled the well back out.
    http://www.infinity-universe.com/~de...n/DCP_1103.jpg
    The drive point tip of the well had folded over and broke off in the sandy loam soil, give me a break...
    Here is a "before and after" of the Chinese made well points:
    http://www.infinity-universe.com/~de...n/DCP_1104.jpg
    Here is the end of the galvanized pipe. As I was driving, the section of galvanized pipe extruded itself into the pipe of the well point, loosening up that joint. Eventhough I had the pipe ends meeting inside the coupling like you're supposed to, it still didn't work...
    http://www.infinity-universe.com/~de...n/DCP_1105.jpg
    http://www.infinity-universe.com/~de...n/DCP_1106.jpg
    Everything has CHINA stamped all over it. And I think that is the reason this well project is pretty much over. I'm going to return all the unused pipe, well point and couplings, and just forget about this well bullshit for now.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by Boston1 View Post
    +1
    Drilling is the way to go with a large enough casing to use a submersible. A sub is so much more energy efficient that it will pay for the cost of drilling over time.
    Jun 2012
    NY, USA
    Local well drillers are like $3000-$4000.
    I just don't need a well that badly I guess.
    And NO, the person who is guessing "deep well drilled" is incorrect. I talked to the DEC and local geotechnical services. In my area, I don't need a deep well drilled, the water table never goes below 12 ft all year. And at 18' is when the shale rock water viens start. So no, I don't need a 100' deep well drilled for $1000's, a shallow well would suffice. It's just too bad everythgin is made in China these days. I can't find well points made in USA, or SCH 40 pipe in my area that isn't from China. I even took a 1.5 hour trip to a well drilling shop to get extra drive couplings, all of them were stamped with China, so was their pipe...
    Feb 2011
    NW Ontario, Canada
    There are two alternative methods for putting down sandpoints. One is the washdown method whereby a special sandpoint with checkvalve is used. PVC casing with inside couplers are often used.
    http://www.campbellmfg.com/brady/faq.htm
    http://www.campbellmfg.com/brady/instructions.htm
    http://www.campbellmfg.com/brady/doc...stallation.pdf
    The other method involves using a solid iron bar on a rope that drives against the point only, rather than driving against the top of of the casing.
    Decades ago, my father and I went down 120 feet using the washdown method with galvanized pipe and traditional outside coupler.
  1. Pumping pond water
    By Gabety in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-28-2010, 08:38 PM
  2. Pond heater...shorting out????
    By Master Brian in forum Electrical Forum discussion & Blog
    Last Post: 11-11-2009, 05:05 PM
  3. wiring up the pond
    By blk90s13 in forum Electrical Forum discussion & Blog
    Last Post: 07-12-2009, 09:40 AM
  4. pond water bathroom
    By bluedogcabin in forum Remodel Forum & Blog
    Last Post: 04-21-2009, 08:21 AM
  5. water won't draw from pond
    By jhs in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-25-2007, 03:20 PM
