Results 1 to 6 of 6
Thread: Recommendations for small half bath floor plans?
    DIY Junior Member toozie21's Avatar
    May 2012
    MD
    Default Recommendations for small half bath floor plans?
    Anyone have a good site (I have turned up empty) for a small half bath floor plan? I am looking to add one into the basement and I wanted to see what ideas were out there. Right now I am considering one where the door is in the center of the long wall (opening out) and on the inside the sink is against one of the short walls (since I have duct work above it and can't get a ton of head room) and the toilet would be on the opposite short wall. I figure this could be done in a roughly 7' x 3' area (I was going to find an example in someone's house to measure), but I wasn't sure if there was anything else out there that would also work (considering i have that duct work to work around).
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    minimum space you need for a toilet is 15" from the center of the flange, so min 30" wide (and 12" from the rear wall if you want a 12" rough-in toilet.) If you had more room, i would allot a few more inches on either side for more breathing room. me, being a bigger guy, it makes it difficult to use a smaller space. think of resale, you never know who will buy your house. the front of the toilet needs to have 24" min. clearance in front of it. This is all from me researching half baths a few years back. i forget what sites i used, but someone will come along and suggest some more info, i'm sure.
    look under "small half bath plans" or small half bath ideas" and use "images" and you can find what you are looking for.
    3' x 7' is the size of my garage powder room, but you may be going at it backwards. FIRST you should decide HOW the piping could be most conveniently installed, THEN work the room layout and dimensions around it.
    May 2012
    MD
    Thanks for all the feedback. It seems like what I have described should work fine for the pumping and drainage in my situation. I definitely have some room to play with, so I was going to look at a minimum, or standard set, then add some more room in like you were mentioning. Nothing worse than being crammed into a bathroom after a day of beer and crabs and thinking you are in a sauna because the walls are right on top of you!
    Yakima WA
    Consider the door opening. Many times folks don't and end up with a door that opens into the toilet space. Make sure you have a 12" rough-in for the toilet, it's much simpler if you don't have to hunt for 10" or 14" toilets.
    Thomasine Adward thomasineaadward's Avatar
    Jul 2012
    752 Jefferson Ave, Brooklyn, NY 11221
    Go for the sliding doors, it will secure huge place of opening.
  1. Second floor plumbing plans and pics....please help.
    By Heat in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-22-2011, 07:09 PM
  2. new half bath plumbing
    By Zenman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-19-2009, 01:48 PM
  3. Floor Plans - What do you think?
    By nelsonba in forum Remodel Forum & Blog
    Last Post: 11-03-2007, 04:28 PM
  4. Adding half bath
    By barryw in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-24-2007, 10:16 PM
  5. Half-bath DWV Rework
    By sopulon in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-30-2006, 08:22 AM
