Thread: Do tubular PVC slip joints loosen over time?
    DIY Member bsperr's Avatar
    Apr 2008
    Athens, GA
    Default Do tubular PVC slip joints loosen over time?
    It's been around a year since I re-plumbed the trap for our kitchen sink with tubular PVC, and I found a large puddle of water in our sink base cabinet a few days ago. When I checked the fittings that make up the trap, I was surprised to find that the connection to the sink strainer and several of the slip joints (a dishwasher wye and baffle tee for the disposal)were no longer even finger tight. I'm certain that I tightened these fittings when I installed them. Do these types of fittings loosen up over time, and do I need to check them periodically to prevent leaks? Or is it more likely that they just got bumped and loosened by moving stuff in the sink base cabinet?
    It's more likely that they got bumped, but pvc does expand and contract quite a bit as it thermal cycles. Some of the cheaper ones the threads aren't all that great, and that could be an issue, too.
    I&C Engineer (mostly WWTP) Lakee911's Avatar
    Aug 2005
    Columbus, OH
    Same with mine. I hear ticking from the sink when running really hot or cold water. I think it loosens with thermal expansion and contraction
  1. Slip-joints & teflon tape / pipe dope
    By DavidTu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-10-2011, 08:22 AM
  2. Are there two types of slip-joints?
    Last Post: 09-10-2011, 07:58 AM
  3. Newbie Question about slip joints.
    By pechan in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-12-2011, 08:23 AM
  4. Question about slip-joints
    By pshannon in forum Shower & bathtub Forum & Blog
    Last Post: 09-10-2007, 10:50 AM
  5. Leaky plastic slip-fit joints
    By Bosun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-30-2005, 05:45 AM
