Results 1 to 3 of 3
Thread: Wall Oven connection - J-box mandatory?
Hybrid View
    Default Wall Oven connection - J-box mandatory?
    Previous oven, a delightful slide in double oven + cook top unit from 1980, was connected directly via 3-wire that came through the floor behind the unit.
    New oven will be installed in a base cabinet in the same location. While in the process of finishing my basement several years ago I was forward thinking enough that I replaced the 3 wire with 4 wire throught the same hole in the floor.
    New oven installation instructions shows that a j-box needs to be installed in an adjacent cabinet. Question is - is the j-box mandatory? If I have enough slack in the cable can I not wire it direcly to the oven?
    Thanks,
    Dan
    If I remember correctly, my memory is excellent, but my ability to access it is not.
    Electrical Contractor jbfan74's Avatar
    Jun 2007
    Newnan, GA
    Does the new oven come with a whip?
    If it does, then you need a j box somewhere to connect the whip to the feed.
    Yes I am A Pirate-Jimmy Buffett
    Took me a moment to figure out what you meant by "whip".
    Looking at the install instructions it appears that it has a flexible metal conduit - which I think is what you mean by whip. It didn't occur to me until you asked that question but now it's obvious - has to be connected to a j-box. Since a cook top will be installed above the oven I may have to put the j-box in an adjacent cab.
    Thanks JBF...
    Dan
  1. #10/3 for single wall oven?
    By Artie in forum Electrical Forum discussion & Blog
    Last Post: 01-05-2010, 04:47 PM
  2. PVC Wall Tube Connection
    By BillM in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-14-2009, 05:26 PM
  3. kitchen p-trap to wall connection
    By chakangt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-11-2008, 04:54 AM
  4. Low flow mandatory?
    By billybarty in forum Toilet Forum discussions
    Last Post: 02-05-2008, 01:43 PM
  5. Oven/Microwave installed on same wall as service panel
    By Boo in forum Electrical Forum discussion & Blog
    Last Post: 07-23-2007, 07:06 PM
