Results 1 to 3 of 3
Thread: Using a HVAC Condensate Pump or Directly Connecting to Sewer Line w/trap
    DIY Senior Member DanMcD's Avatar
    Jun 2005
    Dayton, OH
    Question Using a HVAC Condensate Pump or Directly Connecting to Sewer Line w/trap
    I like some advice on whether I should install a Condensate Pump for my HVAV or just have a plumber directly connect it to my sewer line and use a trap to prevent sewer gas from entering my furnace install. I am having my entire cast iron sewer lines replace with PVC, so I need to decide on how to do this correctly.
    Below is some background info on what I have now...
    My current furnace setup has the A/C & Humidifier draining directly into my 2 inch cast iron sewer line which is under my crawl space. It has been like that for 35 years and has always worked. When this was first installed, the HVAC person:
    (1) Connected the HVAC inch PVC to a inch piece of copper pipe.
    (2) He then bent the copper pipe to make a trap before it would enter my 2 inch cast iron sewer line. This 2 inch cast iron pipe is the drain for my laundry tub.
    (3) He then drilled a hole into the 2 inch cast pipe and connected the inch copper and added silicone caulk. FYI, the 2 inch cast iron pipe connects downstream to my 4 inch cast iron main sewer line.
    What is the best method/correct way to drain my HVAV?
    All traps should be separately vented to prevent siphoning the trap dray. There is no guarantee that between the humidifer or a/c it will drain often enough to keep the trap that's there full.
    Most people either run it outside if there's no danger of freezing and it can be accommodated reasonably, or, dump it into something like the sump pump, or drain it into the top of the washing machine stand pipe.
    You can be ABSOLUTELY certain, that in the winter time, there will be ZERO condensation to keep the trap sealed, therefore the blower unit WILL suck sewer gases into the system and distribute them throughout the house. Either connect it to a fixture's trap connection or use a pump.
  1. Connecting 3.5" IPS to ABS for sewer line extension
    By MrsTiki in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-20-2012, 07:18 PM
  2. HVAC Condensate Pump
    By mallengold in forum HVAC Heating & Cooling
    Last Post: 12-12-2010, 10:04 AM
  3. Condensate Line to Sewer Pipe, NSPC
    By PrezMFL in forum NSPC Plumbing Code Questions
    Last Post: 06-07-2010, 08:55 AM
  4. Condensate Line to Sewer Pipe, NSPC
    By PrezMFL in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  5. Condensate drain line as trap prime
    By michael-thomas in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-23-2005, 06:11 AM
