Results 1 to 7 of 7
Thread: Red Jacket 50N1 control box help.
    DIY Junior Member rhuian's Avatar
    Jun 2012
    Tulsa, Ok
    Default Red Jacket 50N1 control box help.
    Bought this house a few years back and am just now getting around to putting my well to work. I pulled the pump out yesterday and this is what I found:
    RED JACKET, 1/2 HP 208/230 VOLT,60HZ,11H 7.2A,CODE
    L,50N1,3450 RPM,PT.179-314,3 WIRE
    There's no control box in the garage where the wires terminate. If there was one it was cut out. I need to find a diagram or person who knows what sorta Cap I'm going to need when building my own control box.
    Any pointers?
    Moderator valveman's Avatar
    Mar 2006
    No sense in reinventing the wheel. Control boxes are not that expensive. Just get a 1/2 HP Franklin box and you are in business.
    Jun 2012
    Tulsa, Ok
    Thanks, Thats what I was initially going to do but I'd talked to a local guy who didn't think that my particular pump had a Franklin motor. It has a plastic cap on the bottom which lead him to believe it was one of the pumps where Red Jacket used their own motor. I looked for a Red Jacket CB but couldn't find one.
    Is there any real way to tell which motor I'm dealing with and does it matter? Will a Franklin box work either way?
    Feb 2011
    NW Ontario, Canada
    My Grundfos doesn't have a Franklin motor but I use a Franklin control box. Are you sure it is a 3 wire and needs a control box? Maybe it's 2 wires plus ground?
    Jun 2012
    Tulsa, Ok
    It has red, yellow and black. I think 2 wire plus ground would be black black and green?
    Mar 2006
    With just red, yellow, black, without a green you can't be sure. They could be using red, yellow, black because that is the only kind of wire they had. Then they splice it to two blacks and a green at the motor. Really need an ohm meter to see if any of those wires are grounded. If one of them is grounded, it is a two wire motor. If the two lowest ohm readings addup to the highest ohm reading between the three wires, it is a three wire motor and needs a control box.
    Jun 2012
    Tulsa, Ok
    Thanks, I'd already picked up a 1/2 horse control box from Lowes and wired it up and it works!
  1. Red Jacket Hydro Servant replacement
    By Keith45 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-30-2010, 06:03 AM
  2. Damage to CSST jacket
    By Noth Jersey in forum Plumbing Forum Discussion & Blog
    Last Post: 04-28-2009, 07:39 PM
  3. Red Jacket Motor
    By Leaky Boot in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-02-2009, 07:55 AM
  4. CENTIPRO control box problems for Red Jacket
    By weistart in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-17-2008, 04:56 AM
  5. How Good Is Red Jacket Submersible Pump?
    By Daisy in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-14-2008, 07:41 PM
