Results 1 to 3 of 3
Thread: New cold and hot feed to a new bathroom
    DIY Junior Member Rngr275's Avatar
    Mar 2012
    Upstate NY
    Default New cold and hot feed to a new bathroom
    I am having a new bathroom put in and I am trying to figure out the supply line lay out. The bathroom will have a shower stall, toilet and sink. Water suppy will be from the cellar to the second floor. There is only room for a couple Pex lines up the the bathroom maybe more. I was thinking about running a hot and cold pex line up then manifold/tees/??? to the fixtures. Not sure what size PEX to use 1/2 or 3/4 or if I need seperate PEX feeds from a manifold in the cellar. That would be difficult but I might be able to figure out a way. My thought was to (and I am a rookie at best) Run a 3/4 cold up to feed all 3 fixtures and run a single 1/2 hot up to feed the shower and sink (less volume to exchange to get hot water to the shower).
    Also, is it better to use/build a manifold or use PEX tee's?
    McD
    Running a 3/4" cold and a 1/2" would work fine for that. You can tee off in the bathroom for the individuals.
    If you have a large tub, or plan for multiple shower heads, or someone may be using the sink while you're in the shower, use 3/4" for the hot as well up into the room, and consider running 3/4" to the tub/shower, then convert to 1/2" at the valve (unless you buy a 3/4" valve!). The sink could probably get away with even 3/8", but to fill a tub, more is better. Keep in mind that the internal volume of a pipe is Pi*r^2 - the squared factor means that a little difference in r means a BIG difference in cross-sectional area and the pipe's ability to flow with minimal losses and greater volume. If it were only a single shower, 1/2" pex would likely be fine. Pex is smaller ID than copper, so 3/4" pex is only nominally larger than 1/2" copper. The fewer fittings and smoother curves of pex allows it to flow with less restrictions, but that is only part of the equation.
  1. Vacuum relief on cold water feed?
    By vtxdude in forum Water Heater Forum, Tanks
    Last Post: 02-05-2011, 11:09 AM
  2. Bladder to feed a cold water line that has low flow on city water.
    By FBXFixIt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-17-2009, 09:58 AM
  3. Bathroom shower hot/cold reversed?
    By jed1154 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-13-2009, 09:37 AM
  4. Cold water feed makes a right racket
    By Karljay in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-13-2008, 08:56 AM
  5. No Cold Water to Bathroom
    By Jeff_B in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-12-2008, 05:04 AM
