Results 1 to 11 of 11
Thread: Air Sealing Electrical Boxes (Expanding Foam.)
    DIY Senior Member molo's Avatar
    Sep 2006
    cold new york
    Default Air Sealing Electrical Boxes (Expanding Foam.)
    Hello,
    I'm working on a new renovation with new wiring and access to the open framing. I would like to prevent air leakage around all electrical boxes.
    One thought I have is to use expanding foam around the outside of the boxes. Is this OK?
    Thanks in Advance,
    Bill
    "Any American who is prepared to run for President should automatically, by definition, be disqualified from ever doing so."
    Gore Vidal.
    Jun 2007
    North Carolina
    Depends on the foam
    read the instructions
    DIY Senior Member Homeownerinburb's Avatar
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by molo View Post
    Hello,
    Thanks in Advance,
    Bill
    There are specific foams for closing holes drilled to chase NM thru framing. Look at some of that.
    Quote Originally Posted by Homeownerinburb View Post
    Anyone know what this foam is and where it can be found?
    If I remember correctly, my memory is excellent, but my ability to access it is not.
    Feb 2011
    NW Ontario, Canada
    Google is your friend. Search for:
    fireblock foam electrical
    Jan 2012
    Los Angeles, CA USA
    Amen.
    I saw rows and rows of it at Home Despot just yesterday.
    Sep 2006
    cold new york
    I talked to a rep. at Dow today. They said that their standard "great stuff" foam is OK around electrical boxes and insulated wires. However, it is not OK inside the box or in contact with bare copper.
    Gore Vidal.
    DIY Senior Member Chad Schloss's Avatar
    Jun 2010
    USA
    if i were you, i wouldn't use the normal great stuff. get the stuff for windows and doors. it does not expand as much and will not push your boxes out of square if you use too much. it will bow window frames if used incorretly, i've done it myself.
    Jan 2012
    Los Angeles, CA USA
    I'd definitely try to ask a local electrical inspector.
    Electrical Contractor Jim Port's Avatar
    Aug 2009
    Maryland
    I doubt that fireblock caulk or foam is required. The OP is not sealing fire rated areas, except for maybe floor penetrations and that is only is the floor is a rated assembly.
    Jan 2012
    Los Angeles, CA USA
    Quote Originally Posted by Jim Port View Post
    My concern would be that certain products would be banned as blocks around boxes due to their flammability.
  1. Electrical Engineer allowed to do Electrical work?
    By willijimon in forum Electrical Forum discussion & Blog
    Last Post: 03-05-2009, 05:08 PM
  2. Hidden electrical boxes in ceiling.
    By ScottTENN in forum Electrical Forum discussion & Blog
    Last Post: 11-30-2008, 11:40 AM
  3. Connecting low-voltage conduit to electrical boxes
    By Taylor in forum Electrical Forum discussion & Blog
    Last Post: 06-24-2008, 04:02 PM
  4. ground electrical boxes
    By geandham in forum Electrical Forum discussion & Blog
    Last Post: 01-29-2008, 04:11 AM
  5. 1-1/2" deep multi-gang electrical boxes
    By Lakee911 in forum Electrical Forum discussion & Blog
    Last Post: 01-19-2008, 08:46 AM
