Results 1 to 2 of 2
Thread: Wall Hung Glenwall and Sanipak - HELP
    DIY Junior Member cgetty's Avatar
    Jun 2012
    Pennsylvania
    Default Wall Hung Glenwall and Sanipak - HELP
    I am installing an AS Glenwall in my basement and using a sanipak by saniflo macerating pump. I hired a very unrelaiable plumber who obviouslyn never worked with a wall hung before. He ran a water line to where the toilet was going and told me to have the contractor finish the walls before he roughed in the waste and wall carrier for the toilet. Now I have top have someone open the wall and put in the wall carrier. I have a couple of questions:
    1. Do the studs need to be 2x6 or can I get away with 2x4's?
    2. Does the Zurn Bracket sold on Terry's web site work with this toilet? I see that it is for 12 inch center studs... since I am going to have to open the wall and probably move the studs - Is there an adjustable bracket I should buy?
    3. The sanipak intake for the toilet waste is about 7 inches (centerline) from the floor - when looking at the installation instructions for this toilet - it looks like the waste centerline is only about 5 1/2 inches (centerline) at best from the finished floor. How the heck do I install this to get the waste line to have a 3% drop to the sanipak pump? What am I missing as sanipak says it can be installed with any american wall hung toilet? In other words what height do I hang the toilet for the waste outlet centerline to get it to work with this pump?
    Really appreciate the help.
    http://www.saniflo.com/upload/produc...l_sanipack.pdf
    Any bowl will need a bracket.
    The glenwall uses the 4 bolt bracket shown on my shopping cart.
    It's not adjustable; the studs are. To gravity drain to the SaniPak, the bowl will need to be higher then normal.
  1. Wall hung bathroom sink lavatory distance to wall
    By Mike2187 in forum Plumbing Forum Discussion & Blog
    Last Post: 10-21-2011, 05:56 PM
  2. American Standard Glenwall wall mount toilet and Yorkville review
    By Terry in forum Toilet Forum discussions
    Last Post: 09-01-2010, 11:50 AM
  3. Glenwall wall mount toilet
    By chuck1 in forum Toilet Forum discussions
    Last Post: 02-13-2010, 04:38 PM
  4. Glenwall Pressure Assisted Wall-Mounted Toilet
    By Phadamo in forum Toilet Forum discussions
    Last Post: 12-06-2008, 06:38 AM
  5. Kimera / Tessera / Crane / Glenwall wall hungs
    By tippsand in forum Toilet Forum discussions
    Last Post: 05-17-2005, 09:13 AM
