Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: Building a Custom Electric Mirror - Sometimes simple is best!
    Jul 2009
    North Vancouver, BC
    Default Building a Custom Electric Mirror - How to make one
    I have never installed an electric mirror on any of my projects but did see one go in on another builders job about three months ago. I love these mirrors! If you have not visited the website from Electric Mirror you should go take a look. The website for Electric Mirror is here.
    After looking at all the sizes and styles it became clear that we would need a custom mirror and I started the process of getting one made. One thing I hate is having a middle man involved and that is just what I faced here in Vancouver. In order to get a custom mirror I had to first draw it up and then process my order through the local Vancouver fixture store. Well their in Vancouver close to Richmond and I'm in North Vancouver - and what about the cost of a custom mirror???
    As luck would have it I was shipping off a couple drain samples and stumbled upon a custom Glass store. I have been looking for some slumped glass for a shower bench and went in to check out this new shop. What did I find inside? Three versions of the Electric Mirrors!!! Not only that the owner (Moe) was one sight and I got to chat with him from everything from power supplies to french cleats. We designed the mirror together and Moe told me what to prepare for his arrival with the new electric mirror.
    I was blown away at how simple these builds are and can imagine that anyone with a good skill set can pull off building one of these mirrors. I'll be prepping the project these week for the mirror and need to run some low voltage wire for the warm LED's we will be using.
    I'll post a few play by play shots as I think many of you will love the look of this bathroom mirror. The mirror is the last step in a long drawn out renovation that involved firing the original contractor and bringing me and my team in to fix all the problems.
    Stand by for updates.
    In the meantime if anyone else has designed and built an electric mirror I would love to see what you did.
    JW
    DIY Senior Member chefwong's Avatar
    Jun 2006
    District of Columbia
    I presume standard stuff like Keuko or Rohbern did not fit the bill....
    Call me old skool. I'm not a fan of all the glitz and glamour.
    Gimme a aesthetically matching framed mirror or flat non framed (depending on bathroom style).
    Inside power outlets are nice and defogger....but I'll pass on the leds.
    BTW, which leds are you using. IME, the CREE leds are the warmest out there in any variant....
    Jul 2009
    North Vancouver, BC
    Default Electric Mirror - warm white vs cold white LED's
    Quote Originally Posted by chefwong View Post
    ...which leds are you using. IME, the CREE leds are the warmest out there in any variant....
    Good Question. I'll try and find out which ones are going to be used. This is a very contemporary modern designed bathroom.
    The mirror will only measure 12 7/8" tall by 55" wide. The mirror will be 6mil and installed at 'Head' level for my clients. The challenge with this bathroom was having a mirror hung that blocked the windows. Nothing looked good and the client decide to have the window's frosted for privacy and then install a skinny mirror to match the gun slits that we had installed. Once you see the end result I think it will all go great together.
    Here is a look at two styles from my new glass man in North Vancouver.
    Our mirror will have three strips of lights like this measuring 2" x 10 7/8". Because the light will shine trough the window we designed the backs of the mirrors to have a cover. This will increase the output of light and keep all three lights looking the same.
    This is the warm light we are going to use.
    JW
    Jul 2009
    North Vancouver, BC
    Default Designing an Electric Mirror ( 12 7/8" x 55" )
    So this is the design we will be using.
    The LED's will be tucked into a 3/4" U Channel and the power supply will be hidden in the bathrooms vanity. The tricky part will be hiding the low voltage wiring from view but I think I can sneak it in between the window jambs. Lets hope.
    JW
    Jul 2009
    North Vancouver, BC
    Default Electric Mirror - Small Scale Installation.
    A progress update.
    Jun 2006
    I love the whole yet vintage modern theme you're going for.
    Jul 2009
    North Vancouver, BC
    Default Office Task Lighting - LED lighting with heat sink
    We used the same LED lights (Warm Light) to upgrade the home office adjacent to the master bathroom. The LED's where attached to a L Bracket (3/4" Aluminum Stock) as a heat sink. The flat grey colour on the L Bracket matched this IKEA cabinet's door glide hardware perfectly!
    We used an upscale dimmer and transformer so this lighting can be dimmed. Same with the Electric Mirror.
    IKEA Stock Cabinets
    HEAT SINK - L Bracket. Installed with double sided 3M tape.
    Full Power
    JW
    DIY Junior Member SteveBath's Avatar
    Jul 2012
    NC
    Cool! .. If only someone could somehow attach a blowdryer to a mirror .. would save a lot of time in the mornings getting rid of foggy mirrors .. ;-)
    I am surprised you did not put a TV behind the mirror that was visible when it was turned on.
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by SteveBath View Post
    Funny you mention that. I just checked on the mirror and Moe said that he can make these heated as well. The heated mirrors don't fog up I'm told. How nice is that!
    Here is the mirror almost finished. I asked for a lot of light in a very small strip and Moe rigged up a 'LED Booster' of sorts. Since this mirror is hanging in front of window the sunlight can shine through the back side of the mirror and this would make the center light appear different durning the day since it will be covered by a window jamb. Moe came up with a brillant solution and added in extra mirror to box out his LED system. The mirror increases the light output a lot and will give a ton a light I'm sure.
    You can see here the light with no booster on the left and with it on the right. I loved it straight off and green lighted this change!
    I'm glad we went with the warm LED's. I prefer the colour better. It was very interesting the effect of the LED booster with the cool LED's. Not so much of a boost??? I wonder why?
    JW
    JW
    Jul 2009
    North Vancouver, BC
    Default Vancouver Glass Artist
    We did that in another bathroom a couple of years back. It is quite the effect. This mirror is getting hung in front of a window so we are limited in the design. I hired a glass artist from a local North Vancouver shop to build this for me. It's amazing! I chatted the guys ear off and got to see his art glass, carvings and some of his high end finished projects.
    You can check out his website here. http://www.glasstopia.ca/glasstopia.html
    Building these custom electric mirrors is only a small part of his skill set. He has some killer custom panels for showers and some great ideas on wall panels. I'm looking forward to seeing the finished job. I love working with masters like this.
    He's putting some more shots together of a few more electric mirror installs. I'll share them with guys if he lets me. If you would like to see more examples of electric mirrors I posted a new Ideabook on Houzz.com here.
    http://www.houzz.com/ideabooks/30997...lt-in-lighting
    JW
    Jul 2009
    North Vancouver, BC
    Default Custom Electric Mirror Installation - Vancouver Condo
    So it's done. Installed and looking fabulous!
    My clients and I could not be happier with the finished product. It took Moe and his Journeyman maybe 45 minutes to installed it. Some sort of custom mounting bracket he used. I'm not sure how he installed it but it appears to be some kind of French Cleat system.
    The mirror is lined up perfectly with the other glass details in this bathroom since every window is on the same exact level you can see out the bedroom window while brushing your teeth.
    Here is a peak.
    JW
    Jul 2009
    North Vancouver, BC
    Default Bathroom Lighting with an Electric Mirror
    I stopped by for a couple choice pictures at night and wanted to share them.
    The mirror looks great.
    Looking forward to the next one. We are designing a new feature for a Coquitlam project I'm working on.
    JW
    Jul 2009
    North Vancouver, BC
    Default Coloured lights in an Electric Mirror - Coquitlam Chromotherapy Project
    We are designing a new electric mirror for a job in Coquitlam and it will have RGB lights. I'm looking forward to see the light output on this electric mirror with the colour running. I'm hoping that the warm white or cool white outputs the same like the white only led lights.
    I heard the other day that there is a new breed of LED coming that has coloured RGB mixed with White so that the softer pastel colours show better. I'll need to look into this when they come out.
    JW
    Jul 2009
    North Vancouver, BC
    Default Light Up Electric Mirror's featured on Houzz.com
    My last Ideabook was just featured on Houzz.com.
    If you would like a little more info on them check it out http://www.houzz.com/ideabooks/55540...sign-Solutions
    I can not wait to build the one with colour lighting. I still have not seen one like this yet online.
    Still looking.
    JW
  1. Simple electric arc, spark gap.
    By kharris485 in forum Electrical Forum discussion & Blog
    Last Post: 01-04-2011, 11:02 AM
  2. Replies: 6
    Last Post: 12-09-2010, 04:57 PM
  3. Mirror removal
    By HoneySuckle in forum Remodel Forum & Blog
    Last Post: 12-18-2006, 04:46 PM
  4. Building our FIRST custom showerpan...need ADVICE!!!
    By Daniko in forum Shower & bathtub Forum & Blog
    Last Post: 05-31-2006, 08:10 AM
  5. Hot-water heated mirror in bathroom >>> is this easy to put together?
    By looknohands in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-30-2005, 03:44 PM
