Results 1 to 6 of 6
Thread: gfci for lighting
    DIY Junior Member bobyoder's Avatar
    Jun 2012
    Green, OH
    Default gfci for lighting
    Is it necessary to have gfci breaker on a bathroom lighting circuit? Room has vanity light, a fan in center of room and a recessed can in the shower approved for wet location. This is on a 15amp circuit.
    Jun 2007
    North Carolina
    What does the installation instructions say about the light in the shower?
    This is what that will determine if the fixture is required to be protected by GFCI or not.
    The other fixtures, no.
    Often the determining factor is whether the light is high enough that you could not touch it while in the shower stall.
    Jun 2012
    Green, OH
    No the can says it is approved for wet locations with the appropriate trim which I have. I ran across a post while researching another matter which state lighting in damp/wet areas are to have gfci protection.
    Jun 2012
    Green, OH
    Its just under 8 feet so it can't be reached without a ladder
    Jun 2007
    North Carolina
    Just because it is approved for wet locations does not mean that in the installation instructions it says anything about GFCI.
    In the installation instructions that comes with every fixture it will tell you if it needs GFCI.
  1. T8 Lighting and GFCI ?
    By Mike Turner in forum Electrical Forum discussion & Blog
    Last Post: 07-04-2011, 02:53 PM
  2. GFCI Breaker (no GFCI outlets) not working, but not tripped
    By dmotes in forum Electrical Forum discussion & Blog
    Last Post: 12-02-2010, 11:18 AM
  3. lighting needs
    By milkman2010 in forum Electrical Forum discussion & Blog
    Last Post: 11-15-2009, 06:57 AM
  4. Lighting
    By Cookie in forum Electrical Forum discussion & Blog
    Last Post: 01-27-2008, 05:40 PM
  5. GFCI and lighting in bathroom
    By GaryD in forum Remodel Forum & Blog
    Last Post: 02-16-2007, 06:13 AM
